Glenn Posted June 21, 2005 Share Posted June 21, 2005 I have a bad dash rattle on upper left coner. It goes away when applying pressure. The dealer however doesn't know what to do. How can I pull the dash and put a rubber gasket between the main dash and the small dash that incorporates the defroster vent? Link to comment Share on other sites More sharing options...
fbi012 Posted June 21, 2005 Share Posted June 21, 2005 I have the same problem and I'd love an answer as well. Link to comment Share on other sites More sharing options...
Deer Killer Posted June 21, 2005 Share Posted June 21, 2005 hah.. yeah after I fixed some of my rattles others appeared. I at least pinpointed it to the clips all along the back.. It just doesn't sit snugly. Stuffing some foam near the windshield very temporary solution.. Eventually everything loosens up and the dash taps against those clips again. I was thinking about having Subaru do it.. but I think I'm just asking for a huge headache. Link to comment Share on other sites More sharing options...
fbi012 Posted June 21, 2005 Share Posted June 21, 2005 I have a metalic vibration sound coming from that corner (maybe in the door, can't tell) only happens around 3K tho.... try applying pressure on the left A/C vent, if it makes the noise you're hearing then its the A/C vent's cover. I had that rattle and it was killing me, my dealer fixed it after I showed them where it was coming from. Link to comment Share on other sites More sharing options...
timbuktu Posted June 21, 2005 Share Posted June 21, 2005 I have a metalic vibration sound coming from that corner (maybe in the door, can't tell) only happens around 3K tho.... Sounds like the fuel lines. http://legacygt.com/forums/showthread.php?t=5684 Link to comment Share on other sites More sharing options...
mmm def Posted June 21, 2005 Share Posted June 21, 2005 My dealer advised me not to have them try to fix my rattle, said it would only create more rattles in the long run. That's ok, I can't hear it anymore because I am deaf, play my music too loud and my turboback drowns it out. Link to comment Share on other sites More sharing options...
deimos Posted June 21, 2005 Share Posted June 21, 2005 My dealer "fixed" the rattle I had on the drivers side dash/pillar. The worst of it is gone but it still rattles a little bit from time to time, much better tho. Link to comment Share on other sites More sharing options...
Deer Killer Posted June 21, 2005 Share Posted June 21, 2005 My dealer advised me not to have them try to fix my rattle, said it would only create more rattles in the long run. That's ok, I can't hear it anymore because I am deaf, play my music too loud and my turboback drowns it out.0wned Link to comment Share on other sites More sharing options...
MrCoffee Posted June 22, 2005 Share Posted June 22, 2005 Hrm, i guess i am not alone in having this rattle in the dash. Link to comment Share on other sites More sharing options...
