kidomaru Posted April 14, 2014 Share Posted April 14, 2014 I found some rims but I need to know if they will fit my car, Bolt patern: 5x100 with 15mm offset and its 18"x7.5 Any suggestions or solutions are appreciated! Link to comment Share on other sites More sharing options...
Claw Posted April 14, 2014 Share Posted April 14, 2014 Read the FAQ. http://legacygt.com/forums/showthread.php/faq-offsets-sizes-rims-and-tires-gt-xenonk-version-4426.html 7.5" (+40mm to +54mm offset, +55) Likely not. Link to comment Share on other sites More sharing options...
Drift Motion Posted April 14, 2014 Share Posted April 14, 2014 of course they will fit... it's the same as running 9.5 +38 Link to comment Share on other sites More sharing options...
Claw Posted April 14, 2014 Share Posted April 14, 2014 Oh, I was going by the 15mm offset he mentioned. Link to comment Share on other sites More sharing options...
Alex609 Posted April 14, 2014 Share Posted April 14, 2014 yes Link to comment Share on other sites More sharing options...
zanzabar Posted April 15, 2014 Share Posted April 15, 2014 Oh, I was going by the 15mm offset he mentioned. more offset means that the wheels stick out more on the fender side, more backspace moves it to the back of the wheel well. using a 15 offset should look a bit funny without spacers, but should fit. Link to comment Share on other sites More sharing options...
Drift Motion Posted April 15, 2014 Share Posted April 15, 2014 more offset means that the wheels stick out more on the fender side, more backspace moves it to the back of the wheel well. using a 15 offset should look a bit funny without spacers, but should fit. why would it look funny? Link to comment Share on other sites More sharing options...
kidomaru Posted April 15, 2014 Author Share Posted April 15, 2014 Thanks for the responses! Greatly appreciated! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Drift Motion Posted April 15, 2014 Share Posted April 15, 2014 Thanks for the responses! Greatly appreciated! Sent from my iPhone using Tapatalk post some pic of the wheel? rare to see that size and PCD, I assume it's some kind of 3 piece wheel...or just a dual drilled wheel... Link to comment Share on other sites More sharing options...
kidomaru Posted April 16, 2014 Author Share Posted April 16, 2014 guy wants 250 for the set plus the spare. thoughts? Link to comment Share on other sites More sharing options...
kidomaru Posted April 16, 2014 Author Share Posted April 16, 2014 and whats the ideal tire size for these? and thoughts on how they will ride? Link to comment Share on other sites More sharing options...
Drift Motion Posted April 16, 2014 Share Posted April 16, 2014 my guess is that they are +45mm not +15mm, you should double check 225/40/18 tire is the most common/easy to find size Link to comment Share on other sites More sharing options...
.Catalyst. Posted April 16, 2014 Share Posted April 16, 2014 my guess is that they are +45mm not +15mm, you should double check 225/40/18 tire is the most common/easy to find sizeListen to this guy, he is likely correct on the offset. Just looking at the face design of those, they don't look like a +15 to me. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
kidomaru Posted April 17, 2014 Author Share Posted April 17, 2014 So I got them today and here are some pics, 225/40/18 still the best tires for these?http://img.tapatalk.com/d/14/04/18/ujasygyn.jpghttp://img.tapatalk.com/d/14/04/18/y3ezybaz.jpghttp://img.tapatalk.com/d/14/04/18/ysarype5.jpghttp://img.tapatalk.com/d/14/04/18/yragadyd.jpghttp://img.tapatalk.com/d/14/04/18/8u7epavy.jpghttp://img.tapatalk.com/d/14/04/18/yqeje5ut.jpghttp://img.tapatalk.com/d/14/04/18/y4urezev.jpghttp://img.tapatalk.com/d/14/04/18/9uqa7yqa.jpg Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
kidomaru Posted April 17, 2014 Author Share Posted April 17, 2014 my guess is that they are +45mm not +15mm, you should double check 225/40/18 tire is the most common/easy to find size You were close, they are +42mm Link to comment Share on other sites More sharing options...
