NYCdob Posted August 20, 2013 Share Posted August 20, 2013 just smelled oil burning and popped the hood... smoke coming from under turbo area. i see oil on the intercooler only on the turbo side. Where you think this oil is coming from?? turbo?? head gasket?? what else is over there?? Exhaust rusted out and fell apart week ago and now this... Link to comment Share on other sites More sharing options...
rtbrjason Posted August 20, 2013 Share Posted August 20, 2013 I had a similar leak and it was the turbo oil feed line. It was rotted out or broken just slightly below the turbo. It pretty much sprayed the whole area with oil mist.. I resolved it by cutting the line, folding it over and brazing it. I then installed the IPT oil feed line to replace it. Link to comment Share on other sites More sharing options...
NYCdob Posted August 20, 2013 Author Share Posted August 20, 2013 man that sounds alot better than the two things i thought... turbo or head gasket!! I'm gona check that line out soon as it cools off in there... thanks Link to comment Share on other sites More sharing options...
NYCdob Posted August 20, 2013 Author Share Posted August 20, 2013 IPT oil feed line?? what is it and where u get it?? Link to comment Share on other sites More sharing options...
JermTheElf Posted August 20, 2013 Share Posted August 20, 2013 I got the FP oil line and filter, infamous was backordered. Just go to forcedperformance.com Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 20, 2013 Moderators Share Posted August 20, 2013 Is mike going to have more kits made? If so, I have one on the shelf that I could provide--would ask for whatever the replacement value is when Mike has them back in stock. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
rtbrjason Posted August 20, 2013 Share Posted August 20, 2013 You should verify that is your problem first.. Get in there with a flashlight! Link to comment Share on other sites More sharing options...
brawline Posted August 20, 2013 Share Posted August 20, 2013 yep i had the same issue except mine was leaking/ dripping on the up pipe. I had iag replace mine with the P&L kit that they carry. Link to comment Share on other sites More sharing options...
BMXBYKR Posted August 20, 2013 Share Posted August 20, 2013 Hey fella's. I've searched this forum extensively and this is the closest issue I could find that I am having. I am going through a considerable amount of oil I'm talking 2 quarts after say a 1200 mile trip. I see a good bit of oil residue on the top of the turbo oil feed line. I checked inside the tmic turbo flange. There's no oil residue inside. I already replaced both copper gasket/washers on the oil feed line. Do you guys think it is the oil line, internal turbo failure or engine internal problem? Could it seriously be the feed line that's bad? I am doubting that because under boost I smoke a lot out of the tail pipes. Thanks in advance for your help. Link to comment Share on other sites More sharing options...
NYCdob Posted August 21, 2013 Author Share Posted August 21, 2013 Thanks for the help ... I'm getting up in there to look at where its coming from today... just had two motorcycles in the shop i have to get back out ... nice weather at end of summer makes for very impatient bike repair customers. Link to comment Share on other sites More sharing options...
NYCdob Posted August 26, 2013 Author Share Posted August 26, 2013 Don't think its the oil line.... Post pictures in New thread... Any ideas would be big help thanks. http://legacygt.com/forums/showthread.php/help-oil-leak-burning-turbo-ic-area-pictures-213125.html Link to comment Share on other sites More sharing options...
jp233 Posted August 27, 2013 Share Posted August 27, 2013 if you see smoke out the exhaust openings.... it's either going directly into the turbo or it's being lost in compression (rings or valves). The turbo oil feed line can crack/fail, it has happened quite a bit. Make sure you're not dripping from a valve cover gasket, or the rear main/oil separator plate too. Link to comment Share on other sites More sharing options...
