BBPeik Posted May 26, 2017 Author Share Posted May 26, 2017 No one wants an ungreased shaft. It could cause chaffing. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted June 1, 2017 Author Share Posted June 1, 2017 The new yoke for the driveshaft finally came in today. I picked it up from the driveshaft shop today and brought it home. I just measured all the crucial measurements and will return it to the shop tomorrow. Should have the new driveshaft by the end of next week. Sorry for the delays guys. I am trying my best to get this all done, but it is an expensive, timely, and tricky process. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
fredrik94087 Posted June 1, 2017 Share Posted June 1, 2017 ^^^ Your money and your car...no apologies to us. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Zee199969 Posted June 1, 2017 Share Posted June 1, 2017 Yea, we're just excited/happy you are even tackling this project Sent from my Nexus 6 using Tapatalk My "Build" Link to comment Share on other sites More sharing options...
FLlegacy Posted June 1, 2017 Share Posted June 1, 2017 ^Exactly! This may be the best addition to the 5th gen forum yet. It definitely opens up our possibilities for more power. Link to comment Share on other sites More sharing options...
BBPeik Posted June 10, 2017 Author Share Posted June 10, 2017 Picked up the new driveshaft today. I posted a pic of the old versus new below. I did a test fit and it fits perfect( insert inappropriate joke here). So Hopefully I will get time to get everything back together this weekend and will be driving by Monday. Cross your fingers guys. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted June 10, 2017 Author Share Posted June 10, 2017 So I Got everything buttoned up today. I had to modify the exhaust hanger that bolts from the trans to the exhaust as it did not bolt up correctly. Also for some reason the PW intercooler is now farther forward than it used to be. I am guessing the mounting point on the transmission is in a bit different spot, about 20mm forward. Since that is the case, the scoop that goes down to it hits it too early and now the hood will not close. Easy to fix, but just another mod. However, I started the car up and it ran perfectly. I ran the car through all of the gears and all seems to be OK. I will put the wheels on tomorrow and do a test drive, but it looks like everything is going to be good. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted June 11, 2017 Author Share Posted June 11, 2017 Well fellas I had a bit of a hiccup today. Remember a while back when I said that the rear axles were stretched as far as they would go and may not work. Well I took it out for a drive and as soon as I hit third gear the rear axles popped right out of the diff. Fortunately, I was close to home so I was able to tow it home with my lawn mower. So now I need to pull the rear diff out again and see what I can do with the axles. I never checked if our shafts will mate up to the spec b inner. I suspect not, but that will be the first thing I check. Anyway, its not done yet, but its real close. Everything else worked real good. Trans shifted smooth and the center diff is working just right. Sorry guys, but we will just have to wait a bit more. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
GTEASER Posted June 12, 2017 Share Posted June 12, 2017 Don't apologize man! You're breaking new ground here, and we're all excited no matter how long it takes to do it right. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
BBPeik Posted June 12, 2017 Author Share Posted June 12, 2017 Thanks, I appreciate the support. On a side note. Here is a pic of the engine bay all finished with the new CP. Also I just pulled one of the rear axles and am disassembling it as we speak to see how it compares with our factory one. Will update later. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted June 12, 2017 Author Share Posted June 12, 2017 Ok so we have the same problem as all other wrx to sti axles. The inners will not fit on our shafts. Now it looks like I am going to need to lengthen the funky axles I created. Not optimal, but I believe I can make it work. Unfortunately, our cars are wider. SO even if I went with STI hubs this problem would still be there. I will find out more tomorrow and let you all know what I find out. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
Timothy.B Posted June 12, 2017 Share Posted June 12, 2017 I'm sure you've checked but, would maybe the 2015+ axles work? I wasn't sure what year you are using. The 2015 seems pretty similar to ours in terms of size. Timothy.B's 2011 LEGACY 3.6R Link to comment Share on other sites More sharing options...
FLlegacy Posted June 12, 2017 Share Posted June 12, 2017 I'm sure you've checked but, would maybe the 2015+ axles work? I wasn't sure what year you are using. The 2015 seems pretty similar to ours in terms of size. The problem would remain the same, since the axle is probably the same part as our platform currently has, it wont fit into the rear diff or the cups from the spec b axles. Link to comment Share on other sites More sharing options...
Wild Bill Posted June 12, 2017 Share Posted June 12, 2017 Love what your doing and all, but where is the pic of you towing your GT with the lawnmower? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
BBPeik Posted June 12, 2017 Author Share Posted June 12, 2017 (edited) So I went all over San Diego today figuring out a solution to my problem. I finally ended up at Moore performance(machine shop in SD not the blast plate people). He said that he can make me custom cv shafts no problem. So that is the route I am going. I am going to bring him one of each of the shafts and he is going to build me some custom axles that should work perfect. Edited June 13, 2017 by BBPeik My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted June 13, 2017 Author Share Posted June 13, 2017 So I just was cleaning up the shafts before I take them in tomorrow to have the new one made. I figured I would post a pic of the two side by side so you guys could see the difference. The top one is the spec b axle and ours is the bottom. I need one with our length and the spec b spline count on the inner. Ours is 32mm longer than the spec b one. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
Ellesedil Posted June 13, 2017 Share Posted June 13, 2017 So far, are the axles the only thing you've had to have custom fabricated? I know you've had to modify a few things to address mounting issues, but I don't recall having to special order anything up until this point, right? Link to comment Share on other sites More sharing options...
BBPeik Posted June 13, 2017 Author Share Posted June 13, 2017 (edited) Correct. If you keep the r160 you can use the axles but you will have to re gear the diff to 3.90 and get a posi edit: driveshaft was custom too Edited June 14, 2017 by BBPeik My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
fahr_side Posted June 14, 2017 Share Posted June 14, 2017 You have a 1:1 center diff not 1.1:1? 3.545 rear diffs are as common as dirt. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
BBPeik Posted June 14, 2017 Author Share Posted June 14, 2017 Yes. Mine is a 1/1 ratio. I used an 05 transmission. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
FLlegacy Posted June 14, 2017 Share Posted June 14, 2017 In the interest of originality and ease of replacement parts, couldn't we just swap our carrier to a 3.9 ring and pinion with an LSD? Even if it is more expensive wouldn't it save a lot of trouble in finding parts in the end? Link to comment Share on other sites More sharing options...
BBPeik Posted June 14, 2017 Author Share Posted June 14, 2017 Yes you can, or you could source an jdm r160. I found a few that were 3.9. Like fahr_side said though. If you go with one of the 1.1/1 transmissions then you can go 3.54 which is an easier find. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
fahr_side Posted June 15, 2017 Share Posted June 15, 2017 Or you might find a 1.1:1 transfer gear easier to source than a 3.9:1 ring gear and pinion. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
A_A_ron Posted June 22, 2017 Share Posted June 22, 2017 Just read this entire thread and I've got my popcorn waiting for more to be posted. BBPeik good luck with the axles I can't wait to see this thing drive. Build Thread Link to comment Share on other sites More sharing options...
rougeben83 Posted June 22, 2017 Share Posted June 22, 2017 Just putting it out there, but did you look into an automatic driveshaft before going custom? I've done the sti 6 spd swap on my 3rd gen and 4th gen, and each time people told me to go custom ds, but I've just used an auto driveshaft of the same chassis and everything lined up perfectly. Looks good so far! Link to comment Share on other sites More sharing options...
