fredrik94087 Posted June 24, 2015 Share Posted June 24, 2015 Youtube Channel: https://www.youtube.com/channel/UConNXG_0M6n_iw5Cwinb7sA SUMMARY: Latest: Built motor 10:1 ratio (sleeved and line honed, king bearings, manley pistons, manley ibeam rods, new factory crank, arp case bolts) New Heads (GSC Power-Division Valves and Single Beehive Valve Spring Set w/ Titanium Retainers) Valve Job on Heads (not ported) Cobb Flex Fuel kit Okada Projects Plasma Direct Coil Packs Blouch turbo (2015 WRX turbocharger with 50/71mm billet compressor wheel TDO5H turbine wheel & shaft and 15 PSI waste gate actuator Perrin header Fuel surge tank with bulkhead and sealed lines Ohlins coilovers (soon to be AST 5200) Kosei k5r 17x9 +48 (with 5mm spacers for fronts only) 275 tires. 275/40/17 falken rt615k cusco F/R strut tower braces Eibach F/R anti-sway bars Whiteline front lower control arm bushing and positive caster kit Whiteline bump steer kit Beatrush F/R bumper guard replacements Brembo brakes Carbotech xp10/xp8 F/R Perrin oil cooler (6.5+ pints total oil capacity) Killer B Racing Radiator Grimmspeed TMIC Fluidampr Pulley IAG AOS TurboSmart BPV TGV delete EGR block Grimmspeed 3 port EBCS Grimmspeed intake with AEM filter Grimmspeed coated and catted j-pipe Corsa catback exhaust Stillen rear trunk lip (came black I paid for painting) STI rear diffuser (sprayed flat black) Schroth 4 point harness Perrin steering wheel dampener lockdown Perrin pitch stop mount Perrin pitch stop brace STI 2015 transmission STI 2015 differential STI 2015 axles F/R STI 2015 starter CF driveshaft STI short throw shifter Custom Alternator cover Dual Defi gauges (oil pressure and coolant temp) Raceseng Slammer Black shift knob Pioneer 7100 head unit and upgraded speakers Dynamat added to doors VR1 20w50 conventional and Wix XP filter (may run Redline 10w40 or Mobil1 15w50) E-tuned by Mikey Botti. E59 at 22PSI. The difference in the two graphs are the different revs of the e-tune for Mikey. Other than that, the 390whp tune is solid. 2016_10_21 update: Two PDFs attached. The 95 mix is Mishi TMIC at 95 octane vs GS TMIC at 95 octane. The 91 vs 95 is GS TMIC at 91 octane and at 95 octane. Why I use a WIX oil filter: http://legacygt.com/forums/showpost.php?p=5335794&postcount=60 1/4 mile times: 13.396@102.90 64F May 2017 13.747@99.08 74F May 2016Fred 95 Mix.pdfFred 91 vs 95 15 wrx.pdf "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
GTEASER Posted June 24, 2015 Share Posted June 24, 2015 http://ccs.dogpile.com/ClickHandler.ashx?ld=20150624&app=1&c=info.dogpl&s=Dogpile&rc=info.dogpl&dc=&euip=66.234.199.109&pvaid=5a2785bc75f4466da57fab151fdfa4be&dt=Desktop&sid=1830193568.2882075271224.1435184397&vid=1830193568.2882075271224.1426791451.765&fcoi=4&fcop=results-bottom&fct.uid=243283b6629b4828aad7994a67130d48&fpid=2&en=0WEFU%2FZhSoTF%2FFm%2BpLeuVl4UPZzISdzyg%2BaGYj7N8ISb7M1aTnzzgA%3D%3D&du=http%3A%2F%2Fcdn.qualitylogoproducts.com%2Fblog%2Fwp-content%2Fuploads%2F2013%2F04%2Fthe-office-make-it-stop.gif&ru=http%3A%2F%2Fcdn.qualitylogoproducts.com%2Fblog%2Fwp-content%2Fuploads%2F2013%2F04%2Fthe-office-make-it-stop.gif&ap=10&coi=772&cop=main-title&npp=10&p=0&pp=0&ep=10&mid=9&hash=7F4C47C18C1473889983928D5224BF12 GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
dgoodhue Posted June 25, 2015 Share Posted June 25, 2015 Congrats on the WRX purchase. Unless Subaru comes out with a 6MT Legacy GT, I have decided that I am going to buy a new WRX as my next daily driver. I would say that I will join you but given that you are on your third car since I bought my '12, I would guess you will be onto another car by the time I buy a WRX. Link to comment Share on other sites More sharing options...
dgoodhue Posted June 25, 2015 Share Posted June 25, 2015 This thread is also worthless without pictures Link to comment Share on other sites More sharing options...
fredrik94087 Posted June 25, 2015 Author Share Posted June 25, 2015 It is even more worthless when I tell you Fiona is wearing Shrek's soles on her own new shoes. 275/40/17 flaken rt 615k at +48mm offset fits with fronts rolled and rears trimmed on oem suspension. There is plenty clearance on the inside for some negatve camber. Shrek could not fit 275 with oem struts. They rubbed with +45mm offset...3mm less than Fiona's shoes. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted June 25, 2015 Author Share Posted June 25, 2015 pics...finally "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted June 26, 2015 Author Share Posted June 26, 2015 I ordered black Brembos from KNS Brakes...326mm/318mm F/R. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
whitetiger Posted June 26, 2015 Share Posted June 26, 2015 you bought the wrong tires. Bridgestone RE-71R is where its at. Link to comment Share on other sites More sharing options...
fredrik94087 Posted June 26, 2015 Author Share Posted June 26, 2015 you bought the wrong tires. Bridgestone RE-71R is where its at. I didn't buy them...Shrek donated them to Fiona...FTW!!! And, I have a second set at home. The Bridgestones are not available in a 275/40/17. If I went with 255/40/17, the Bridgestone was one of my choices. The other ones were ZII Star Spec and AD08R. The latter for better wet handling. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
GTEASER Posted June 28, 2015 Share Posted June 28, 2015 I ordered Brembos for the STI through KNS Brakes. They will be here late July or so. 326mm 4 piston fronts and 318mm 2 piston rears in Gold. Else, it was going to be $200 extra per axle for Black. Buy me some fronts for the Teaser......please... J/k you've got a sickness Fred. Have you signed up for a track day yet? Lol! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
fredrik94087 Posted June 28, 2015 Author Share Posted June 28, 2015 Disease is a better word. LOL. Funny you should ask. Got an email for Thunderhill 2 mile course on July 6. Seriously contemplated it but dunno. Car has only 600 miles on her and wont be properly broken in by then. Even if I dont wring it out, oem brakes are going to suck at the track. I could try it with better pads but it wont be the same and I will just overheat my brakes. Soon enough my friend. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Perscitus Posted July 3, 2015 Share Posted July 3, 2015 4th of July enabling.... http://forums.nasioc.com/forums/showpost.php?p=43575205&postcount=7740 Link to comment Share on other sites More sharing options...
THE RZA Posted July 3, 2015 Share Posted July 3, 2015 Nice, I just picked mine up yesterday, no plans on modding it just yet. Maybe in AP in the near future. Link to comment Share on other sites More sharing options...
cryo Posted July 3, 2015 Share Posted July 3, 2015 Looking good Fredrik. Its definitely more like the LGT than the previous gen wrx or sti in terms of refinement and quality of interior/features. I really like mine and don't regret getting rid of the Sti at all. If your looking for any parts or tuning let me know. I offer a discount on the tune if the ap is purchased through us. Dave http://legacygt.com/forums/attachment.php?attachmentid=211987&d=1435947959 [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
fredrik94087 Posted July 3, 2015 Author Share Posted July 3, 2015 Yikes...already ordered AP from Cobb. But, looking for more info on two potential paths: 1. All stock car with "very safe" 91 tune with potential to hit the track and flog the $hit out of it running the 91 map with 100 octane fuel. I know it won't gain power like my 3.6R did with 100 octane. I would do it for the margin of safety. 2. TMIC and J-pipe tuned to 91 octane. Same rules as above. 3. Your suggestions to keep the car stock-ish and quiet. Laguna Seca has a 90db sound limit. I will get in touch soon enough. Brembos aren't due until end of July anyway. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Philberto Posted July 7, 2015 Share Posted July 7, 2015 Noticed you mentioned having a 1000 mile break-in oil change. Are you doing that for piece of mind or did the dealership do it? Curious because my new Forester XT calls for the first change at 6000 mi. That even bothers me because I change the oil in the GT every 3750 mi. Link to comment Share on other sites More sharing options...
fredrik94087 Posted July 7, 2015 Author Share Posted July 7, 2015 For my own piece of mind. I will change again at 5,000 miles and then every 5,000 miles after that. For some new motor builds a 100 mile oil and filter change is recommended. AP has arrived. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
THE RZA Posted July 7, 2015 Share Posted July 7, 2015 I emailed a shop close to me about doing a 1,000 mile oil change, they recommended doing it at 3,000 just because there are important components in the original oil that need to soak/bond in with the engine Link to comment Share on other sites More sharing options...
cryo Posted July 7, 2015 Share Posted July 7, 2015 For my own piece of mind. I will change again at 5,000 miles and then every 5,000 miles after that. For some new motor builds a 100 mile oil and filter change is recommended. AP has arrived. These cars tend to be a little louder with cat backs than the older uel design. Be carefully with your choice if you look for quiet. The ap will get you hooked as these engines have a lot of potential. Some of the ones I have tuned with a stage 1 put down the same as a stage 2 sti Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
fredrik94087 Posted July 7, 2015 Author Share Posted July 7, 2015 I emailed a shop close to me about doing a 1,000 mile oil change, they recommended doing it at 3,000 just because there are important components in the original oil that need to soak/bond in with the engine oops! They didn't disagree. Funny how you can get different answers from different places. I got three different answers for an unrelated question when I spoke with three shop foremen of different dealerships. Did you check with a local race shop or with subaru? These cars tend to be a little louder with cat backs than the older uel design. Be carefully with your choice if you look for quiet. The ap will get you hooked as these engines have a lot of potential. Some of the ones I have tuned with a stage 1 put down the same as a stage 2 sti Dave OTS stage 1 91 octane is in. Too soon to tell, but I like the fact that boost doesn't hit 22psi at 2,000 rpm. The car is a lot more linear. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
THE RZA Posted July 8, 2015 Share Posted July 8, 2015 I contacted a local race shop. I hate going to the dealerships for their asinine pricing Link to comment Share on other sites More sharing options...
fredrik94087 Posted July 10, 2015 Author Share Posted July 10, 2015 The boost and rev surge is gone. The car is actually driveable. I just discovered flat foot shitfting feture...wow! I wish I used it at the 1/4 mile track. Revs can be set up to 8000. I set it to 3000. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
THE RZA Posted July 10, 2015 Share Posted July 10, 2015 flat foot shifting feature? Link to comment Share on other sites More sharing options...
fredrik94087 Posted July 10, 2015 Author Share Posted July 10, 2015 If you haven't, get an accessport and flash the appropriate map. Well worth the money. Flat foot shifting...you start out in first gear, push in the clutch, shift the car into second, and release the clutch. You do not lift your foot off the gas pedal. You may program at which rpm you wish the revs to be maintained in that split second it takes to shift. I chose 3,000 rpm. So, what happened while I shifted? The revs "slowly" went down toward 3,000 rpm, but my shift was done by the time the revs hit 5000 rpm, and off I went. In normal shifting where you lift off the gas without the flat-footing it, revs drop "fast" and the car bogs when you let go of the clutch. My EVO 8 did not have this problem, but this 2.0 DIT twin scroll does have this problem. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
cww516 Posted July 10, 2015 Share Posted July 10, 2015 Might be worth raising that a little if you plan to use it for higher gears. I haven't actually used it at all, though, so I don't really know how fast the revs drop off. Does setting it that low keep you in boost? Also, launch control exists, that should be fun once the novelty of flat foot shifting wears off. I'm actually curious about the final drive, though- does the formula [current gear]+"0" = [speed at 2000 RPM] seem at all accurate (10mph in 1st, 20 in 2nd, etc.)? I'm sure the easier way to check would be to look on cars101.com and compare, but my phone internet sucks at work. Just wondering exactly how similar the new WRX is to the 5th-gen GT. Link to comment Share on other sites More sharing options...
