Stock suspension + aftermarket wheels
LegaLude
I've come into the possession of 225/45/17's
When testing fitment of the new wheels I turned in a manner that shifted the weight and a small portion of the tire rubbed the wheel well.
I know that there is a common problem with the saggy butts. Originally I was looking into stiffer springs, because I figure the shocks are decent. Although I was suggested to save my money for coilovers and just drive nicely until then.
Any other suggestions or ideas?
Not so sure you need COs. I don't want them for my DD at all. A good strut/spring combo will be better for street performance and comfort compared to most budget friendly COs. Unless of course you are going for extreme low or stance I say stick with strut/springs.
Bilstein HD or Konis with pinks or epics are well reviewed here.
It is a 35 offset.
I'm not sure what all the specs might be. I have only just become aware of some of the technicalities that encompass wheels :/
I thought to roll the fenders, except that I've never personally done it or had it done to one of my cars.
I'll definitely look into the strut/spring assembly. My only concern being how much a setup might lower the car. I had glanced at some Tein H tech springs since their height reduction is minimal.
As well as those spacers for the rear assemblies; although I don't know if it'll make much difference. I'm not sure how much the spring/strut compressed in order to lift the tire into the wheel well like that. Maybe 4 inches. Not sure if the pics will help much, but these are the ones I got just after we tested the fitment, and they came right back off.
Also, someone mentioned to me something about a negative camber bolt? I usually don't mess with all those settings.
