bettner12 Posted May 9, 2014 Share Posted May 9, 2014 Event: dyno pull Location: Innovative Tuning, Buffalo NY Ambient Temp: 55 degrees Fahrenheit Elevation: 620 feet above sea level Weather: wet Tires: Crusade HP Car: 2005 Subaru Legacy GT Sedan Tuner: Mike @ Innovative Tuning Dyno Info: Mustang AWD dyno Transmission: Stock 5 speed Subaru gearset Gear: 3rd Peak HP at RPM: 407@6150 Peak Torque at RPM: 372@5700 Baseline hp/tq for a stock on same dyno: 08 STi = 240 hp Target Boost: 21psi Target AFR: varies with boost Fuel: pump 93 octane Engine -2006 wrx ej255 Approx. 30,000 miles on engine -banjo bolt filters removed -Killer Bee Oil Pickup -Killer Bee Windage Tray -TigWerks -10AN oil return fitting -MSI Billet Motor Mounts -Subaru Engine Block Heater -AN -4 oil feed to turbo -Forced Performance .125 orifice turbo oil filter -AN -4 coolant feed to WasteGate -GrimmSpeed Lightweight Crank Pulley -Tomei Timing Belt guide -Fumoto oil drain -Element tuning vented Catch can -Brad Penn 20w-50 Racing oil -Purolator Pureone oil filter -Brisk stock heat plugs Fuel System -DeatschWerks DW300 intank Fuel pump ( hardwired to battery 20A fuse, controlled with relay, 100% duty cycle) -Injector Dynamics top feed ID1000 injectors -Factory hardlines to firewall -Russell EFI quick disconnect to AN -6 fittings -Fuel labs 10 Micron in line fuel filter -Aeroquip starlite AN -6 fuel lines with crimp fittings -Peterson fluid systems -6,-6,-6, Y block -Moore Performance fuel rails -Aeromotive A1000 EFI bypass regulator Turbo and Exhaust -BorgWarner s256 ( T-3 Twin Scroll,.76 A/R ) -Moore Performance twin-scroll header -Moore Performance twin-scroll T-3 up pipe -Moore Performance rotated v-band 3” down pipe -Perrin Mid, Y, and axle back exhaust -GrimmSpeed 3 Port Electronic Boost Controller -Single 44mm Tial MV-R wastegate (watercooled) -Kartboy XL exhaust hangers Driveline -05 legacy GT 5 speed -Moore Performance BlastPlates -WRX single mass flywheel -ACT HDG6 sprung 6 puck clutch -ACT heavy Duty Pressure plate -TS3K Clutch Release Bearing Kit -Cusco Transmission mount -Whiteline Transmission cross bracing bushings -Kartboy Short throw shifter -Kartboy front shifter bushings -Kartboy rear shifter bushing -Kartboy pitch stop -All four wheel bearing/hubs replaced at ~120k -ARP extended wheel studs -20mm wheel spacer -Torque solutions Solid drive shaft carrier bushings Cooling -Red samco silicone radiator hoses -Allstar racing Coolant de-aeration tank (utilizing stock coolant flow paths) -OEM oil “cooler” deleted -Moore Performance MooreCool Street coolant Braking -STi Brembos -DBA 4000 Rotors -Ferodo DS2500 pads Front and Rear -TIC Titanium backing plates, Front and Rear -TIC Titanium Wheel bearing shields, Front -Goodridge braided SS lines -Grimmspeed Master Cylinder Brace -2005 Sti Brake booster and Master cylinder -ATE Super Blue brake fluid -Mach V rear bracket for Brembo conversion -RooDucts brake ducts Intake system -4” intake V-band to turbo -Green Filters cone filter -Tial 50mm Q Blow off valve -OEM drive by wire throttle body -Big plenum, long runner Impreza 2.5i Intake manifold (Mild gasket match) -KS Tech 19mm phenolic intake manifold spacers -4” Legacy GT Extreme Turbo Systems front mount core (~1200cfm approx) -2.5” 6061 aluminum charge piping Calibration -Cobb Accessport v2 ( will be running full SD) -AEM 3.5 bar MAP sensor -GM fast acting IAT sensor ( located right before throttle body -JDM STi Gauge pack (made by Defi, boost, oil pressure, Oil temp) -Defi Racer Gauge EGT gauge ( in runner #4) -Innovate LC-1 wideband AFR controller -Innovate G3 Wideband AFR gauge -Testmode, Fuel pump, EBCS, and ABS are on a switch panel in the center console -Blitz FATT advance+ turbo timer -On Rails Engineering (O.R.E.) F1 style shift light Suspension -KW V2's w/ Vorshlag camber plates front/ spec B top hats rear -400lb/in Spring rate -Rear spring perches with radial torrington bearings, rear -Whiteline KCA334M Anti-lift caster Kit ( solid) -Whiteline KSR207 steering rack bushing kit -Whiteline KCA313 Roll Center kit -Whiteline W0506 Control arm - lower inner front bushing -Kartboy Solid endlinks, Front Charging System -Odyssey PC680 battery (in pass. side of trunk) -Blue seas systems 150A circuit breaker on 2GA power wire to engine bay -Blue sea systems safety hub 100 fuse block -Carol Super Vu-Tron welding cable 2Ga for all power supply (190A rated @ 100 feet,1666 strand, 34 AWG stranding) -Carol Super Vu-tron Welding cable 6Ga for all chassis grounds(105A rated @ 100 feet 660 Strand, 34 AWG stranding) • Abrasion-resistant • Resists oils and solvents • Rated -50ºC for use in cold environments • Weather-resistant • Ozone-resistant • MSHA approved for flame resistance • Sunlight-resistant Excerpt from Moore Performance: "We were fortunate to be able to use Bettner12's Legacy GT for some R&D on our latest twin-scroll offerings; you can tell this car was put together by Bettner12 at a big boy shop: The Race Place in Wampum, PA. As the build sheet suggests, it's teeming with modifications and attention to detail that you just don't see on many stock-engine Subaru's. "Properly engineered" is another way to put it. The result was a drama-free dyno session at Innovative Tuning, as Mike was able to extract outstanding numbers from this super-solid build. Testing for this round was deemed a success - wide, flat torque curve with no boost drop-off/creep and solid power numbers on 93 octane suggest that things are working as planned, with at least another 100+ HP left in terms of compressor/turbine/IC efficiency. Future plans are more than likely proprietary, and include bottom and top end work, and perhaps a slightly different turbo from the Borg Warner lineup...not to mention a healthy dose of E85 We'd like to thank Clinton for working with us on this project and for logging many many hours behind the welding mask/lathe/mill et.al. Many thanks also go out to The Innovative Tuning crew, The Race Place, Green Filter USA and Team O.R.E. " Link to comment Share on other sites More sharing options...
.Catalyst. Posted May 9, 2014 Share Posted May 9, 2014 Impressive build! My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
subie3429 Posted May 9, 2014 Share Posted May 9, 2014 Awesome build, that engine bay looks like it means business! Link to comment Share on other sites More sharing options...
idiot4hire Posted May 11, 2014 Share Posted May 11, 2014 Great shop I had my car tuned there Link to comment Share on other sites More sharing options...
lingling1337 Posted May 11, 2014 Share Posted May 11, 2014 Wow! I hope I see this as a kit available soon. Amazing build with all the custom piping. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 12, 2014 Share Posted May 12, 2014 Yes, very impressive. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
solo413 Posted May 12, 2014 Share Posted May 12, 2014 Looks great, video clip of sound when you can would be great! Link to comment Share on other sites More sharing options...
Th3Franz Posted May 17, 2014 Share Posted May 17, 2014 Nice curve. A little surprised the car's boost threshhold wasn't a little earlier. still, I bet it spools very quickly at the proper rev. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Eliott Posted May 17, 2014 Share Posted May 17, 2014 Was this at the last qsl pgh meet? Link to comment Share on other sites More sharing options...
bettner12 Posted May 18, 2014 Author Share Posted May 18, 2014 Impressive build! Thanks! its been a long time coming! Awesome build, that engine bay looks like it means business! it was built with function foremost, just happened to look half decent afterwards too! Great shop I had my car tuned there the tuning experience with mike was great, i make no hesitation to recommend mike to anyone looking for a tune. Wow! I hope I see this as a kit available soon. Amazing build with all the custom piping. thanks, not sure if this will get to the point where it's a stocked kit on the shelves, but it would definitely be possible. Yes, very impressive. All the piping ended up being WAY cheaper than any kit out there, just need to be able to fit up piping and weld Looks great, video clip of sound when you can would be great! once i get my desktop set up from school, i'll edit together a quick vid and post it up! Nice curve. A little surprised the car's boost threshhold wasn't a little earlier. still, I bet it spools very quickly at the proper rev. when i'm running spring pressure(1 bar), the gate opens at 3500, lots of head room left on the turbo kit and the inter-cooling system, so the next stage should stretch its legs a bit more Was this at the last qsl pgh meet? Yes it was, first one i've made it out to in about a year and a half. Link to comment Share on other sites More sharing options...
Eliott Posted May 18, 2014 Share Posted May 18, 2014 Glad I caught it, nice ride man. Link to comment Share on other sites More sharing options...
FiftyTwoEighty Posted May 25, 2014 Share Posted May 25, 2014 Elegant and brutal at the same time. Sent from my Lumia Icon using Tapatalk Link to comment Share on other sites More sharing options...
bettner12 Posted June 1, 2014 Author Share Posted June 1, 2014 After the Pittsburgh cars and Coffee meet, we went to a local place (Jergels) to grab some lunch with some of the crew, then 6 of us went for a cruise afterwards for a couple of hours on some fun roads. The Legacy needs an oil cooler sooner than later, but besides that there was no issues, no drama, and it ran up with the rest of the pack consisting of a Lotus Evora, two elise's, Porsche Turbo, and the F430. Owner of the 430 gave me props on the car when we stopped at the mansion, and said how he couldn't hear his car anymore once my ewg opened up Link to comment Share on other sites More sharing options...
bettner12 Posted June 25, 2014 Author Share Posted June 25, 2014 finished up a decent edit of the dyno vid, gopro is still covered with mud from the Kansas Baja SAE competition, so it won't be going back into my car until it's clean. Hopefully this gives you a good idea of the sound! [ame=http://www.youtube.com/watch?v=DA54b0Nzxm4]2005 Legacy GT 406whp Moore Performance built, Innovative Tuned - YouTube[/ame] Link to comment Share on other sites More sharing options...
InTheBay Posted July 4, 2014 Share Posted July 4, 2014 Goddamn son, are you on stock internals? Link to comment Share on other sites More sharing options...
bettner12 Posted July 4, 2014 Author Share Posted July 4, 2014 Goddamn son, are you on stock internals? Yes. if not, much more boost than 21psi would have been run. This is just a data point for the future. Link to comment Share on other sites More sharing options...
bettner12 Posted September 30, 2014 Author Share Posted September 30, 2014 Checking in for an update: So far 8,000 miles on the build, engine and trans are holding up just fine Front Rotors and pads are going to be coming up pretty soon though. Have new Nitto NT-05R's in 235/40/17 and loving them so far. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 30, 2014 Share Posted September 30, 2014 Great to hear it's all holding together. I received my Moore Blast Plates yesterday. Well have them on in a couple weeks. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
