spacematt Posted April 5, 2013 Share Posted April 5, 2013 I just had a new SMFW and clutch installed in my LGT, but the installer forgot to put in the TSK3! They used the new OEM TOB that came with the clutch kit. Needless to say, I was pissed! Should I have them crack everything back open just to install the TSK3? Had new axel seals put in when the job was done too. Everything feels fine with the new clutch and the pedal feels like butter now. They also said the snout was not damaged. What do you think I should do? Can't talk to the guy until next week as he is out of town. Thanks for your thoughts. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted April 5, 2013 Moderators Share Posted April 5, 2013 Make them install it of that's what was supposed to be done. If you chose to forget it, contact me about sellin the TSK3 "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
mwiener2 Posted April 6, 2013 Share Posted April 6, 2013 Never seen a damaged snout. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ibr_adam09 Posted April 6, 2013 Share Posted April 6, 2013 When I had my clutch replaced I purposely put the tsk3 kit with my clutch kit and took the clutch tob home with me, just in case they happened to forget lol Link to comment Share on other sites More sharing options...
impretza Posted April 6, 2013 Share Posted April 6, 2013 I would make them instal it, I installed my new clutch and did not do the TS3 kit because of a delay in shipping. Long story short, 2000 miles later I had to remove the transmission again and Install the TS3 kit due to wicked annoying squeak. Link to comment Share on other sites More sharing options...
lilbrudder Posted April 7, 2013 Share Posted April 7, 2013 :redface:So is your kit up for sale now? Link to comment Share on other sites More sharing options...
.Catalyst. Posted April 7, 2013 Share Posted April 7, 2013 Never seen a damaged snout. http://legacygt.com/forums/showthread.php/why-not-drive-dyeing-clutch-tob-horrors-inside-p4371065.html#post4371065 My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
mwiener2 Posted April 7, 2013 Share Posted April 7, 2013 I didn't say it doesn't happen... and in F1's case, it's probably something about him and his car. That is not typical at all. Damaged snout is a fairly rare occasion. In the 5 years I've been working on Subarus, I have never seen one, Neither has the 3 other techs I work with. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
BIGPAT57 Posted April 7, 2013 Share Posted April 7, 2013 if it was discussed when you made the agreement to have the work done the shop legally has to do the install free of charge. take it back and get it done before its to late! Link to comment Share on other sites More sharing options...
RabidWombat Posted April 7, 2013 Share Posted April 7, 2013 It depends if you want to be a jackass about it or not. The reality is that its not a hugely common failure. Based on the number of posts around here, I'd bet you'll lose ringland #4 before the TOB. If you do demand they take it apart and add it, that's a huge amount of effort for them. Go back and complain, but the best solution is probably them just giving you a discount on the labor already done, and you re-selling the part or having it put on with your next clutch. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 8, 2013 Share Posted April 8, 2013 I vote for having them install it. My 2000GT wagon had it's tranny snot replaced at around 63,000 miles. There was no kit for it back then, but the dealer knew what to do. They had a local machine shop make up a insert and installed it after having the case machined to except it. They seemed like they had done this fix before. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
