strmdrgn Posted February 21, 2012 Share Posted February 21, 2012 i just installed LED DRL/high beam bulbs the other day. with the DRL module plugged in, i have no low beams and the DRL/high beam bulbs are lit dimmly and the high beams work fine. with the DRL module unplugged, i have low beams and the DRL/high beams are lit dimmly still. also the high beam indicator on the dash is lit dimmly with the low beams on. i was just wondering if anybody else has run into this problem. any information would be greatly appreciated. Link to comment Share on other sites More sharing options...
