enzotheracer Posted February 17, 2012 Share Posted February 17, 2012 Wondering if wrx would fit my 91 wagon fwd. Also wondering where I can get that 19mm sway bar anlong with new engine and tranny mounts. Any info will work. Thanks. Link to comment Share on other sites More sharing options...
1994BC Posted February 17, 2012 Share Posted February 17, 2012 Going through this as we speak though for a 94' fwd sedan. 03-07 wrx will swap on front no issues you even can reuse mounts etc. Rears would work IF you had awd being as you don't you can just order some KYB rears for $125 at the moment. Good info here Best price atm here I swapped WRX fronts mounts and all. Then just picked up 92' wagon rears to level out the rear which has ~100lbs of tools making life hard on already blown struts/weak springs. KYB's should be here before days end. Link to comment Share on other sites More sharing options...
enzotheracer Posted February 18, 2012 Author Share Posted February 18, 2012 Why won't the rears work for the wrx work? Link to comment Share on other sites More sharing options...
1994BC Posted February 18, 2012 Share Posted February 18, 2012 Because the rear spindle is different on awd. The strut mount on the spindle for awd is offset from center towards the front of the car and placed higher. While fwd mount is at the center both vertically and horizontally roughly on the spindle. On the left WRX right fwd legacy. You'll see as a result of the difference in spindle the WRX bottom spring perch is lower on the strut tube than the fwd legacy. When mounted your perch and tire won't clear each other by ~3/4". http://i56.tinypic.com/atvxmu.jpg Link to comment Share on other sites More sharing options...
enzotheracer Posted February 18, 2012 Author Share Posted February 18, 2012 So could I use the spings of wrx on the wagon shocks? Link to comment Share on other sites More sharing options...
1994BC Posted February 18, 2012 Share Posted February 18, 2012 Not sure why you would put WRX springs on the rear as their spring rate it 119-144 depending on sedan/wagon manual/auto. Meaning they would be softer than your wagons which are rated at 179 likely causing a drop. http://bbs.legacycentral.org/viewtopic.php?t=2153 The WRX on the front have net me zero change in ride height but are stiffer than the 94' fronts. 123 ->163 I still have blown rears and 100lbs of tools in the trunk so after putting on the rears the nose may come down some. I have 92' wagon rears, 07' WRX rears, and 94' sedan rears here I'm about to have all laid out in a swap today. I'll take plenty of pictures and let you know what I find. Link to comment Share on other sites More sharing options...
1994BC Posted February 19, 2012 Share Posted February 19, 2012 http://legacygt.com/forums/showpost.php?p=3756513&postcount=9 Link to comment Share on other sites More sharing options...
enzotheracer Posted February 19, 2012 Author Share Posted February 19, 2012 Cool. Thank you very much for your time and all the info this really helps me out a whole lot. I too need rear struts due to lugging around tools and friends all the time. Link to comment Share on other sites More sharing options...
