ThatVAguy Posted February 13, 2012 Share Posted February 13, 2012 I'm looking at buying XXR 522's and I love the concavity of the +38 offset...but I cant find any sites selling that in the 18x8.5(what i originally wanted). What extra steps do i need to go through on a 9.5 to get it clear on our cars/is it possible? Clearly fenders will have to be rolled. I'm on stock suspension now, but I'm suppose to be sending my car in to be used as a prototype for an unnamed suspension company's venture into LGT territory Link to comment Share on other sites More sharing options...
Drift Motion Posted February 13, 2012 Share Posted February 13, 2012 8.5 won't have the concavity 9.5 needs fender roll what is your question? Link to comment Share on other sites More sharing options...
ThatVAguy Posted February 13, 2012 Author Share Posted February 13, 2012 answered lol. I thought it might need more than just a fender roll. i also priced out the 255/35/18s and the difference in tires alone was enough to steer me away. im gonna roll on the +48 and see how i like them and if not, ill sell. thanks for the help man Link to comment Share on other sites More sharing options...
Drift Motion Posted February 13, 2012 Share Posted February 13, 2012 with stock suspension, stick with the 8.5 9.5 will look real funky without some suspension mod... and you can run 225/40 Link to comment Share on other sites More sharing options...
spoolin13 Posted February 13, 2012 Share Posted February 13, 2012 do you know if 527's 17x9.75 +25 will fit? Link to comment Share on other sites More sharing options...
mk6933 Posted February 14, 2012 Share Posted February 14, 2012 do you know if 527's 17x9.75 +25 will fit? You need to be lowered, roll, pull, and stretch tires. If so, then it will fit. Link to comment Share on other sites More sharing options...
thisisthenewsic Posted February 14, 2012 Share Posted February 14, 2012 18x9.5 won't fit without Coilovers with camber plates and whitelines camber adjustment in the rear. You will need a roll/pull with stretched tires. I had to do ALOT of work to make 18x9.5 +30 front +38 rear with 255/35. Link to comment Share on other sites More sharing options...
SpecBGuy Posted February 14, 2012 Share Posted February 14, 2012 do you know if 527's 17x9.75 +25 will fit? good luck with that.. i have 18x8.75 +35 w/ 225/40/18 but should of gotten 235 just fender roll and swift springs. Link to comment Share on other sites More sharing options...
Drift Motion Posted February 14, 2012 Share Posted February 14, 2012 18x9.5 won't fit without Coilovers with camber plates and whitelines camber adjustment in the rear. You will need a roll/pull with stretched tires. I had to do ALOT of work to make 18x9.5 +30 front +38 rear with 255/35. with 225s, you can do without rear camber adjustment the "natural" camber from lowering should be enough Link to comment Share on other sites More sharing options...
whitetiger Posted February 14, 2012 Share Posted February 14, 2012 he should be able to swing a 245/35/18 on a +48 8.0" or 8.5" rim too without much modification too. Link to comment Share on other sites More sharing options...
