sliCCriC Posted January 11, 2009 Share Posted January 11, 2009 how did i reset the CEL light? Link to comment Share on other sites More sharing options...
KnifeyMcShanker Posted January 12, 2009 Share Posted January 12, 2009 I don't know, how did you? If you had the battery disconnected for a while, that may have done it. Link to comment Share on other sites More sharing options...
tbssubaru Posted January 12, 2009 Share Posted January 12, 2009 ya i want to know now too, how did you do it ? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted January 12, 2009 Share Posted January 12, 2009 Did you use your carputer to do it? I did Either disconnect the battery, or use an OBDII reader ($35 online - handy tool to have). Link to comment Share on other sites More sharing options...
ehsnils Posted January 12, 2009 Share Posted January 12, 2009 I think that the OP has a '91, so it's probably the battery method, or using the infamous connectors the right way. Link to comment Share on other sites More sharing options...
Bdubs Posted January 12, 2009 Share Posted January 12, 2009 No readers necessary for the 90-94 Legacy OBDI cars. OBDI, reset it by connecting both blacktoblack and greentogreen connectors under the dash. Turn the ignition to ON, but do not start the car, depress gas pedal all the way for at least 10 seconds. Start the car up, and drive it for about a mile keeping the car over 10mph, once the codes are cleared it will blink 1/2 second interval flashes. Then, you can turn the car off and disconnect the plugs. You can also disconnect the negative terminal of the battery, but this doesn't always seem to work 100% all the time. Link to comment Share on other sites More sharing options...
987687 Posted January 14, 2009 Share Posted January 14, 2009 how did i reset the CEL light? CEL light is redundant Link to comment Share on other sites More sharing options...
sliCCriC Posted January 14, 2009 Author Share Posted January 14, 2009 ok smartasses how DO i reset the cel light?..... it that better Mr. Proper? Link to comment Share on other sites More sharing options...
jonklein611 Posted January 14, 2009 Share Posted January 14, 2009 No readers necessary for the 90-94 Legacy OBDI cars. OBDI, reset it by connecting both blacktoblack and greentogreen connectors under the dash. Turn the ignition to ON, but do not start the car, depress gas pedal all the way for at least 10 seconds. Start the car up, and drive it for about a mile keeping the car over 10mph, once the codes are cleared it will blink 1/2 second interval flashes. Then, you can turn the car off and disconnect the plugs. You can also disconnect the negative terminal of the battery, but this doesn't always seem to work 100% all the time. Link to comment Share on other sites More sharing options...
gathermewool Posted January 14, 2009 Share Posted January 14, 2009 ok smartasses how DO i reset the cel light?..... it that better Mr. Proper? at the responses. Smart asses...Well, the info for how to clear the CEL is listed above, but the more important questions are what the CEL code is, and why you want to clear it. '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
tbssubaru Posted January 15, 2009 Share Posted January 15, 2009 you should disconnected the battery and then pushed the brake pedal, wait 10 minutes and reconnect , the CEL light light would did be off at this point until it camed on again , if it do be comed back on then i would have looked at what the code was first Link to comment Share on other sites More sharing options...
sliCCriC Posted January 19, 2009 Author Share Posted January 19, 2009 grassyass senours !! Link to comment Share on other sites More sharing options...
tbssubaru Posted January 19, 2009 Share Posted January 19, 2009 day knotta Link to comment Share on other sites More sharing options...
wiscogtlimited Posted January 21, 2009 Share Posted January 21, 2009 take it to autozone..........free scans. Just had a cel for a shot knock sensor..........60 bucks........30 minutes of wrenching.....done! Link to comment Share on other sites More sharing options...
Bdubs Posted January 21, 2009 Share Posted January 21, 2009 OBDI doesn't consist of using a scanner. All you have to do is count blinks to determind CEL's. Link to comment Share on other sites More sharing options...
