Guack007 Posted July 30 Share Posted July 30 Does anyone know how adjustable the alignment is stock and what it takes to be able to change it? I saw that Subaru and the aftermarket make some eccentric bolts that seem like the easiest way to add camber but I’m just not sure what’s really possible. Link to comment Share on other sites More sharing options...
Guack007 Posted July 31 Author Share Posted July 31 Took my stock 2024 Legacy Sport in to the alignment shop and learned the following information which might help some folks. The camber in the front can be changed independently stock. Here is the max they were able to get out of the front of mine while keeping the toe at pretty much zero: Front Left Camber: -0.81 degrees Front Left Caster: 6.47 degrees Front Right Camber: -0.63 degrees Front Right Caster: 7.05 degrees I didn’t max out the rear but here is where we decided to set it at: Rear Left Camber: -1.79 degrees Rear Right Camber: -2.02 degrees Link to comment Share on other sites More sharing options...
0SuperDuper0 Posted August 14 Share Posted August 14 (edited) I recently did mine and the rears are now at -2.5 camber and the advisor said its alright because they cancel out? Is that normal within spec? I know some negative camber is good but is that excessive and what problems could come up if I keep driving? The front is all good and in green. Edited August 14 by 0SuperDuper0 Link to comment Share on other sites More sharing options...
