High speed vibrato
JMLegacy
Symptoms are:
1. Braking at high speed induces vibration
2. When brake is released, car is still vibrating for a minute or so
Idk if the rotors cause this as I recently skimmed n got new pads, and the fact that it still vibrates after I stopped holding the brake, Idk,
Also I only see the problem of I'm doing over 110 or so
Any ideas?
It's the rotors. The pad are still making contact with the roots even if you aren't on the brakes. The shake takes a moment to spread the pads far enough apart so that it stops.
Excellent point, I didn't consider that.
Also, once you do the work properly bed them.
