archer1.8 Posted January 29, 2013 Share Posted January 29, 2013 Ok so about a week ago I bled my brake system. The pedal was squishy since i owned it. So I bled the brakes doing the proper sequence. Had my dad pump the brakes. Took the car for a test drive and what a difference! It felt like a new car. About an hour later driving back to college I stopped at a red light and the brakes felt like the use to. I don have any leaks, pads are all new. So not sure where to go from here Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 31, 2013 Share Posted January 31, 2013 Ok so about a week ago I bled my brake system. The pedal was squishy since i owned it. So I bled the brakes doing the proper sequence. Had my dad pump the brakes. Took the car for a test drive and what a difference! It felt like a new car. About an hour later driving back to college I stopped at a red light and the brakes felt like the use to. I don have any leaks, pads are all new. So not sure where to go from here You can try a gravity bleed and see if it helps. Put the car on stands, remove the wheels, grab some pans or cardboard or big towels (4), one for each wheel and put them under the rotor/caliper. Remove the master cylinder cap, fill with clean fluid, and open all 4 of the bleeder screws and let them drip. PAY ATTENTION to the master cylinder so that it doesn't go below half full and let them drip for 15 minutes or so. This is how I flush my own systems because it doesn't invade the master cylinder bore by pushing the pedal down further than the normal travel and it always works. They will drip slowly but you'll see the fluid come out of them and the weight of the fluid will slowly force any bubbles in the system to come out of the bleeders. I've been doing brakes this way for many years and have never had it not work, even if I replaced a very long section of brake line. Link to comment Share on other sites More sharing options...
Wicked Posted January 31, 2013 Share Posted January 31, 2013 I would maybe take a look at the master cylinder? That could be the cause of squishy pedal. Link to comment Share on other sites More sharing options...
archer1.8 Posted February 2, 2013 Author Share Posted February 2, 2013 What exactly would i be looking for on the mc Link to comment Share on other sites More sharing options...
JmP6889928 Posted February 5, 2013 Share Posted February 5, 2013 If the MC were bad, the pedal would slowly go all the way to the floor. You stated that they were just soft and mushy, so I would believe there is still air in the system. Link to comment Share on other sites More sharing options...
KCwagon Posted February 6, 2013 Share Posted February 6, 2013 The ABS sensor portion of the brake system CAN trap and keep air in the system. This is usually requires a SUBARU dealership to bleed the system with a vacuum pump. Link to comment Share on other sites More sharing options...
JmP6889928 Posted February 9, 2013 Share Posted February 9, 2013 You can buy a Mityvac fairly cheaply now and vacuum bleed them yourself. Link to comment Share on other sites More sharing options...
