Help with audio upgrade in 2008 Legacy
jordymac5049
Hi all,
I've got a 2008 Legacy 2.5i Limited. I want to upgrade by buying my own speakers etc on my own and then have them professionally installed. I am finding it hard to figure out exactly what i need though. FYI this is my first time upgrading a system in a car so these might be juvenile questions, Sorry!
Things I know I need:
4 6 1/2" speakers plus 2 1" tweeters
Subwoofer
Amp
I am assuming whichever crutchfield cerfied tech I choose will have any brackets or wiring that I need.
Am i missing anything? Thanks!
Welcome to the forum. Uhh... where to start...
If you're going to have the speakers professionally installed, is there a reason you wouldn't have the installer also source the speakers? If going that route, I would just have the installer work up an itemized estimate and then have the installer price match the hardware with Crutchfield.
Backing up a little further... what are you trying to do, exactly? Get more volume? Better sound? I got a long way with a quality head unit, sub amp & subwoofer.
Tits mcgee
The right front speaker rattles so i think its blown. I figured that if i am going to replace i,t I might as well make an upgrade to the whole system. I want better sound quality than the stock speakers. I also want to add a sub. I like the tuner because it already has all the options I need (CD, AUX, FM/AM, and SAT)
I was planning on getting an estimate but I also reached out to the community because I wanted to see what all i would need. Like I said, total novice.
My limited has the HK system... does yours as well? There is a 7-channel (I think) amp that powers that system. You should keep in mind that you need to match the impedence for that amp, or just replace the amp with a new one. Do some searching on your system in this forum, you'll find what you need.
Tits mcgee
I would definitely suggest trying to pick out our own speakers. You need to audition them and make sure you like the sound. Different sets of speakers can sound very different. If you just ask the shop to pick a set for you, you might end up with expensive speakers that you hate.
MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII
IMO, picking your speakers is the most important step. If you have a local car audio shop, chances are they have a wall with most of what they carry installed so you can audition them. Listen to them all, even if they're out of your price range, so you can learn what sounds you like and what you don't. It's not a bad idea to take your own CD so you can hear how they sound with your music. Once you know the sound you like, you can either pick a set you liked at the shop or search the interwebz for something that would suit you better.
Pay attention to the tweeter material between sets you like and those you don't, because it's one of the bigger factors. Soft tweeters (like silk) generally aren't nearly as harsh sounding as metal tweeters (like titanium).
Bomber - I have auto climate control. They ask this too on crutchfield. Do you know why?
There is an adapter for the manual controls for you to install a new head unit.
Auto climate requires a more expensive adapter that Crutchfield doesn't offer.
'08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust
How is the sound quality with the factory 6 disc changer head unit when just upgrading 4 door speakers and running an amp to power them? Worth it? Or does the head unit really hold everything back?
WWW.MODDICTION.COM
Moddiction Stainless steel and Titanium shift knobs.
Drivetrain, suspension, brakes, exhaust, cooling, fuel, gauges+MUCH more!
