Your 2013 plans for your Subaru??
ust wondering what people have planned for their beloved Subaru's, park it up and only drive it once in a blue moon, sell it on, more upgrades, respray different colour? Be good to see what guys have in the pipework
My plan is:
New LM450 billet twinscroll turbo
lateral performance 850cc injectors
New tune
Whiteline anti roll bars
Whiteline anti lift kit and bump steer correction kit
New strut/springs or coilovers
Fix up a few bodywork issues
Get wheels resprayed
Get a track day in too!
Should keep me busy for a few months
Who's next?
  • Replies 64
  • Created
  • Last Reply
My plan is:
Replace All Mounts & bushings - fix all clunks, squeaks, rattles,
Upgrade Struts & Springs
New Summer tires
Bring to the dealer for an alignment.
DW fuel pump & 850cc injectors
Upgrade the tune from Stage 2+ to Stage 3.
Dynamat the trunk area to lighten drone a bit.
Save to give the powertrain a complete overhaul.
Go on a cruise through the Mountains, maybe even get in a track day.
Enjoy the car.
Well I've got a lot of plans, we'll see what actually happens but here they are:
-New Wheels/Tires: Thinking Rota Gravels at this point
-JDM Double Din kit with all new speakers, sub, etc.
-Hella Horns
-RRev Spec Grill
-New Exhaust
-Stage 3 at some point
Swift Springs
Koni's
New Summer Tires
Whiteline Rear Sway wtih AVO Brackets
Custom Mid/Y Pipe with Perrin Mufflers
Subtle Atl Cover
Serious Engine Bay Cleaning
New Rear Bumper
Front Bumper Quick Disconnects
Powder Coat Black Racing Wheels Gold/Bronze
i think you are the only one! I was like you 4 years ago when i first got my legacy, i said "this car, i will leave stock, its great the way it is"
That last about 4 weeks, and i got a CBE and tune and Tein springs!
  • I Donated
Mine was stock for about 5 months, and I told myself at first that I wouldn't do any upgrades. But coming from a car where I had 4 times as much in mods as it was worth in stock condition... yeah, right. :lol: Took me until month 3 to start researching, and then I decided to upgrade when I had to drop in a new engine. "While I'm in there..." :lol:
But, my plans for 2013 are to buy and install the following things:
IP&T oil line
Perrin UP blanket
Gaskets, etc. for turbo install
South Bend Stage 2 Daily 6MT clutch
And then to install the following things that I already have:
BNR Evo 16G (and possibly get a dyno tune)
PTP turbo blanket
BP TMIC kit
Koni Yellows
IP&T oil line
Perrin UP blanket
PTP turbo blanket
BP TMIC kit
Koni Yellows
Fulton, what are the benefits of the IP&T oil line. I should probably upgrade.
  • I Donated
No benefits on stock turbo. In fact, it may hurt. The oil line has a much higher flow rate than the stock metal lines. The higher flow rate can blow out the seals on the stock turbos, from what I hear.
On upgraded turbos, it provides the higher flow rate they need for proper oiling, but also has a high-flow filter to prevent damage due to oil contamination. BNR requires it to honor the warranty on his turbos.
Thanks for the info man. I will def get one once I upgrade the turbo
What's in my cart at Infamous Performance site. Still debating if I'm going to pull the trigger on everything now.
http://www.infamousperformance.net/media/01/a20792012d01144520869f_s.jpg Give me more room for FMIC pipes.
CLG-RSD-MSM-LGT Mishimoto Subaru LGT Fan Shroud
http://www.infamousperformance.net/media/00/a20791c12bf3f6c2c3d3cd_s.jpg Time to do again in Feb.
ENG-GTS-TMC-SUB Gates Racing Complete Subaru Timing Kit
http://www.infamousperformance.net/media/00/a20791c12bf412c56ce8e6_s.jpg OEM as good size rust blister on it. Don't know if I wont to expand my oil system to 8qts. It's already 7qts. Just mite be overkill :spin:;):lol:
ENG-PUP-KRB-SUB Killer B Subaru Oil Pick Up & Oil Pan
http://www.infamousperformance.net/media/00/a20791c12bf40f4ffd11a_s.jpg If I get the pan. I mite as well get this.
ENG-BFT-KRB-SUB Killer B Oil Baffle / Windage Tray
http://www.infamousperformance.net/media/00/a20791712c0000789df096_s.jpg Needed
DTT-MTM-STI-SUB Group N Motor Mount's
(Left D1010FE120)
(Right D1010FE110)
http://www.infamousperformance.net/media/00/a20791712c0002248fa0bc_s.jpg I mite as well get this.
DTT-PST-STI-SUB Group N Pitch Stop Mount
This is what I'm thinking about. I already have the Mishimoto Radiator & Sti 6MT mount installed.
Mileage:331487 Retired/Sold
Keep it stock (unmolested) and carry out preventive maintenance. How many non mod owners out there?
I lasted about 3 months stock until my TOB went.. Then I decided to upgrade the clutch and TOB to prevent premature failure. That led to a new LW SMFW, plus all transmission mounts/bushings. The real mods started a few months after that, once I got connected with a local tuner. Now it takes serious self control not to buy parts with every paycheck. I've got the bug..
IP&T oil line
Perrin UP blanket
PTP turbo blanket
BP TMIC kit
Koni Yellows
"While I'm in there.." is an easy way to spend 2 to 3 times what you were going to spend in the first place.. My TOB ended up costing me close to $1400 in parts because of this logic.. not to mention going stage 2.. :eek:
