dahoseman Posted November 19, 2012 Share Posted November 19, 2012 Sorry, this is about an Outback XT instead of a LGT, but I figured the electrics are essentially the same and there's a lot more traffic on here than the outback forum. I recently bought my 5MT 2005 OBXT and it was fine until a crappy electrical problem developed today that is beyond me. My cruise control was acting a bit jerky on a drive and then stopped working as i was driving it. It then showed a flashing 'Cruise' light on the dash. I decided to unhook the battery power cable, clean the terminals, and let it sit unhooked for a few hours while I was indoors and let it clear to see what would happen. When I hooked the battery cable back up later, it turned over just fine, but it had difficulty starting and I had to turn it over several times to get it to start. It was idling a little rough, but I figured the ECU had been reset and needed to relearn again. Over the 8 minute drive back home, the idling did not improve and it nearly stalled at stop lights. The ABS light also came on. When I was parking it at home, it stalled before I could shut it off and I noticed all of the dash electrical lights/systems were off even though the key was still in and on. I tried to restart it, but it nothing came on. It was as if it had a 100% dead battery, except the battery is fine and the electric seats work fine. I couldn't get the window rolled up because it does not respond without the ignition working. The keyless entry does not respond. I checked and cleaned the battery terminals/cables again and went through every fuse on the car without success. It's currently sitting in my driveway with the window down, completely unresponsive except for the electric seats. Any tests, thoughts, suggestions? Is my ECU fried? Does that cause the ignition to not respond? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 19, 2012 Share Posted November 19, 2012 How old is the battery ? You say it's fine, but don't tell us the voltage in the battery. It's hard to believe the battery is fine when you tell us this type of info without giving hard facts. Have you tryed to jumper cables from another car. Next time you get a CEL have it read for free at any auto parts store. BTW, CC alway's flashes when you get a CEL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 19, 2012 Moderators Share Posted November 19, 2012 MaxCap alluded to it, but the flashing cruise light is a precursor to the engine throwing a CEL. Instead of clearing it by unplugging the battery, get it read next time so you have an idea of what's going on. Post the code up here and people will usually be quick to help. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
__raj Posted November 19, 2012 Share Posted November 19, 2012 I had similiar symptoms and it turned out to be a bad alternator more specifically the regulator jumping voltage making car go haywire. I never got a CEL and dash was haywire including dash warning lights on/off like a christams tree and jumping instruments etc. Link to comment Share on other sites More sharing options...
mikeyd Posted November 19, 2012 Share Posted November 19, 2012 Yeah find out what codes are thrown and in the meantime you may want to check out the various threads on the OCV (oil control valve) issue. Many have experience the ruff idle/stall due to the ocv going faulty and not moving the intake cam shaft(s) back to low rpm position. Add one-touch operation (and more) to your stock sunroof Link to comment Share on other sites More sharing options...
dahoseman Posted November 19, 2012 Author Share Posted November 19, 2012 Unfortunately, I can't do any of those things. There is nothing "on" to read. It's not driving/starting, anything. The car is essentially a paper weight right now. I can't even get the window rolled up because it doesn't turn on with the ignition. When I say that it has no response, I mean nothing comes on. No dash back lights, no radio, no lock/unlock, keyless entry does not respond at all, nothing. Yet, the seats work fine (not slugglish or pulsing power) I hooked up my Forester with the engine running by jumper cables (to the car cables themselves, not just the battery terminals) just to make absolutely sure it's not a battery or terminal connection, there was no change or response. I even took the battery out of the OBXT and put into the forester just to see what happened. The Forester started and worked just fine with the OBXT battery. Once again, the seats work fine and the driving lights come on if I flip the steering column "on" switch. And just to reiterate, all obvious fuses are intact, both under the dash and under the hood. I took the steering column plastic off and connected a jumper cable lead to my circuit tester on a few wires. I got a light on the tester at the starter wire when I turned the key, so it's got a ground through the circuit. However, nothing came on. I haven't seen anything like this before on any vehicle, so I am at a loss. If anyone has any idea what I should look at or test next, please let me know. If nothing else, I would just like to get the driver's window up before it rains/snows. I have just have to 'jump' the window with a cable from the battery. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 19, 2012 Share Posted November 19, 2012 I'm thinking now its in the key or the ignition switch in the colume. Wiggle the key as your turning it to start 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dahoseman Posted November 19, 2012 Author Share Posted November 19, 2012 Thanks for the advice/info. I have been wiggling every wire, key, connection I can think of just hoping it's a loose connection, but I haven't gotten so much as a flicker. Is there a safe way to jump that to test the ignition? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 19, 2012 Share Posted November 19, 2012 I had similiar symptoms and it turned out to be a bad alternator more specifically the regulator jumping voltage making car go haywire. I never got a CEL and dash was haywire including dash warning lights on/off like a christams tree and jumping instruments etc. OP, try pulling the connector off the Alternator and then try starting the car, if it starts, I think you have fouind the problem 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dahoseman Posted November 20, 2012 Author Share Posted November 20, 2012 OP, try pulling the connector off the Alternator and then try starting the car, if it starts, I think you have fouind the problem Thanks for the suggestion. I unhooked the harness and tried. Then I did the harness and cable. Still no dash lights. Any suggestions for getting the window rolled up? Question: If it was the ignition, shouldn't the keyless entry lock/unlock still function? Link to comment Share on other sites More sharing options...
dahoseman Posted November 20, 2012 Author Share Posted November 20, 2012 BTW, I'm getting desperate to at least get the window rolled up so that it's not snowing or raining in my car. I'm going to have to either put plastic over the window or dig into the wiring to jump the driver's window. Any suggestions for that? Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted November 20, 2012 Share Posted November 20, 2012 Real long shot, but just for the hell of it try another key. Link to comment Share on other sites More sharing options...
dahoseman Posted November 20, 2012 Author Share Posted November 20, 2012 Unfortunately, I only have one chipped key and one remote, otherwise I would try that. I'm trying to figure out what electrical system controls: (NOT WORKING) -Keyless entry (lock/unlock, rear hatch, panic) -All ignition systems (dash gauges, all interior lights, windows, sunroof, radio, etc) -Start But does not control: (WORK FINE) -Driving lights (switch on top of steering column) -Electric seats Link to comment Share on other sites More sharing options...
MAP Posted November 20, 2012 Share Posted November 20, 2012 I havent looked at the battery or distribution box for this car but it sounds like there may be bad/ burned open fusible link. Usually there are a couple wires running from the battery's positive battery terminal. One goes to the starter and the others go to the power distribution box where there are relays or fuses. It sounds like possibly the fusible link of one of these wires is burned open or wire is broken. Use a test light to probe these wires as they go to the distribution box. It sounds like one is ok since you have power to a couple items. The other possibility is that one of the main ground wire connections is loose or broken. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 20, 2012 Share Posted November 20, 2012 ^x1, sounds like its time to measure voltage from the battery to the next items down the line. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dahoseman Posted November 20, 2012 Author Share Posted November 20, 2012 It was in fact the fusible link. I've dealt with them before on some old Toyotas, but I was used to all electrical devices passing through a large single master "oh shit" fuse. It was really confusing that certain features still had power, so I didn't even think it could be that. In any case, it looked fine from the top with shiny clean terminals and it must have been flowing just a enough electrons to give my circuit tester an LED light on both terminals. However, I unbolted it and the bottom was covered in some flaky black stuff that almost looked like exhaust ceramic (corrosion?). I jumped the terminals with some pliers and things started working. Voila! The ABS light is on now, so I'll look for codes when I get back in town. Thanks for everybody's input and advice. Even with the possibilities that turned out to be fine, I know a little bit more about my car now. Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted November 21, 2012 Share Posted November 21, 2012 Glad you figured it out and it turned out to be a minimal cost problem. Also thanks for posting the solution. A lot of these threads the OP disappears and we're left no knowing if it ever got fixed. Link to comment Share on other sites More sharing options...
dahoseman Posted November 21, 2012 Author Share Posted November 21, 2012 Oh yeah, I wouldn't post and not give the answer to the puzzle. That doesn't help anybody. Thanks to all puzzle solvers. I feel a little stupid not figuring out that it was a fusible link. In my defense, the fusible links that I have previously encountered on other vehicles regulated ALL battery power as a last-ditch safety against a catastrophic power discharge. In summary for any future similar posts, the "Main" fuse controls everything but seats and driving lights. Link to comment Share on other sites More sharing options...
