leg_gt_limited Posted November 13, 2012 Share Posted November 13, 2012 I have a 2005 legacy gt limited manual, 143000 miles. The smell of burning oil has been around for the last six thousand miles. Had it checked out and nobody could find anything wrong. Now when my car idles for awhile whether I'm warming it up or at a stop light, smoke/steamy oil vapor comes out from my hood scoop. When the hood is popped I can see the steam coming from the turbo area. The smell is the strongest inbetween the turbo and the cold air intake (mounted in factory location) Possibly where the intake manifold is.... My guess is a bad intake or exhaust manifold gasket, or valve cover gasket, not sure though. Any help would be greatly appreciated, thanks Link to comment Share on other sites More sharing options...
mwiener2 Posted November 13, 2012 Share Posted November 13, 2012 If you have a stock intercooler, it took a poop My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Matt166 Posted November 13, 2012 Share Posted November 13, 2012 There are a couple of active threads on this. I have been trying to pinpoint my leak for about a month. I tightened a couple of bolts on my valve cover gasket last week and the smoke has subsided a little but the smell is still there - im hoping its just burning excess oil at this point. You should check: Pass CV boots Oil return line on base of turbo Coolant lines on turbo Oil lines on turbo There are a couple of other seals to check, but I cant remember what they are. Link to comment Share on other sites More sharing options...
lowwill Posted November 14, 2012 Share Posted November 14, 2012 ^^ Like he said^^ Link to comment Share on other sites More sharing options...
adreyna Posted November 14, 2012 Share Posted November 14, 2012 ^^^ What the guy above this guy said! I had a similar issue and it turned out to be a torn cv boot... try lifting up the car to see what you can see Link to comment Share on other sites More sharing options...
Max Capacity Posted November 14, 2012 Share Posted November 14, 2012 Most likely valve cover gasket, but check the CV boot too, they have also been known to let go. New axles are about $80.00 at the auto parts store. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
eljefe1981 Posted November 17, 2012 Share Posted November 17, 2012 Mine was doing the same thing, but now I only smell it slightly and see no smoke. Please forgive my ignorance but how would the CV boot cause this? Link to comment Share on other sites More sharing options...
shadowsports Posted November 17, 2012 Share Posted November 17, 2012 It cracks or rips... grease flies out onto the DP or engine and white smokey appears. Link to comment Share on other sites More sharing options...
eljefe1981 Posted November 17, 2012 Share Posted November 17, 2012 Oh ok, that makes sense. Link to comment Share on other sites More sharing options...
