kaitanium Posted June 18, 2019 Share Posted June 18, 2019 (edited) Has anyone had experience with SPC Performance? Looking at their rear lower control arm (67660 EZ Cam) as im lowering my outback and wanted more adjustability when getting the car aligned. Local shop recommended that to me as a part that should fit but im not 100%. Or a more expensive Cusco 6ai474ln. Both of these arent listed as fitting a legacy or outback. In any case, what lower control arms that dont use a poly bushing are you guys running? Whiteline KTA124 is a poly one but is also an option. Edited June 18, 2019 by kaitanium Link to comment Share on other sites More sharing options...
awfulwaffle Posted June 18, 2019 Share Posted June 18, 2019 Both the arms you listed look like the arms on my 13 WRX, not my LGT. Maybe they're cross-compatible? No issues with the KTA124 arms here, though. You might want to hit up SubieRecycler.com and see if they have a used set. I've seen them there before for $200-$250. Link to comment Share on other sites More sharing options...
SesnaBlue Posted June 19, 2019 Share Posted June 19, 2019 My adjustment bolts rusted and froze up. Went with whiteline. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
kaitanium Posted June 19, 2019 Author Share Posted June 19, 2019 subierecycler looks like an incredible resource! no response from them yet... been trying to read about why poly bushings arent recommended. Cant find a definitive answer. the whiteline sway bars i have on have those bushings and i find them just fine Link to comment Share on other sites More sharing options...
SesnaBlue Posted June 20, 2019 Share Posted June 20, 2019 subierecycler looks like an incredible resource! no response from them yet... been trying to read about why poly bushings arent recommended. Cant find a definitive answer. the whiteline sway bars i have on have those bushings and i find them just fine Hmm I’d be interested to hear why. I don’t track mine I just don’t like replacing parts with OEM. I have always heard poly lasted longer and was better. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
awfulwaffle Posted June 20, 2019 Share Posted June 20, 2019 Poly will start to squeak sooner in my experience. When I did the rear suspension bushings and the KTA124 arms, I wrapped them all in a layer PTFE tape tape before greasing to see if it helps. Also noticed the bushings and threads in my KTA arms were bone dry out of the box, so silicone grease/antiseize there too. No squeaks yet, but it hasn't been long enough. Link to comment Share on other sites More sharing options...
