NavigatorsLegacy Posted June 18, 2019 Share Posted June 18, 2019 Horn stopped working. Depressed horn. No sound at all. Checked fuse box under hood. One 7.5 amp fuse was blown for Horn Cntr. Now makes a barely audible but faint horn noise when depressed. Changed Horn Relay. Still does not work. Horn sounds muffled like under pillows and faint. Any advice welcomed...supposed to go on a trip soon need advice for dad of 3 on a budget.. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
stewdogg Posted June 18, 2019 Share Posted June 18, 2019 Sounds like the high and or low horns are going or have gone bad. They are pretty easy to replace... they are the first two options on the page in the link below. https://parts.wildesubaru.com/productSearch.aspx?ukey_make=5806&ukey_model=89998&modelYear=2011&ukey_driveline=53362&ukey_trimlevel=110403&searchTerm=horn Link to comment Share on other sites More sharing options...
GTEASER Posted June 18, 2019 Share Posted June 18, 2019 I am going to guess that the unrelenting east coast weather in combination with road salt is probably the downfall of the horns. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
ripstik Posted June 18, 2019 Share Posted June 18, 2019 check that your grounds on the horns are good. after that you've ruled out the horn switch it self, the relay, and the fuses so the only thing left is the horn itself. if you are really trying to save some dough amazon has plenty of cheap and less cheap options. these hellas are slightly less expensive than the stockers https://www.amazon.com/HELLA-011225802-Black-77mm-Universal/dp/B01C8F0AUY/ref=sr_1_4?keywords=car+horn&qid=1560895388&s=gateway&sr=8-4 Link to comment Share on other sites More sharing options...
08SpecB_DE Posted June 19, 2019 Share Posted June 19, 2019 +1 for the horns. They may have water damage. Link to comment Share on other sites More sharing options...
NavigatorsLegacy Posted June 26, 2019 Author Share Posted June 26, 2019 I live in NJ and the weather is crazy hot 100 degrees in summer and cold -15 in winter. Also it rained a bunch here too..water damage on Hella Supertones? Only lasted 2 yrs... smh Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted June 27, 2019 Share Posted June 27, 2019 this is my recommendation https://smile.amazon.com/Hurricane-Chrome-Compact-Vehicles-Motorcycles/dp/B07MSBRWSY/ref=sr_1_20_sspa?crid=135N3GWXYZYIE&keywords=car+horn&qid=1561635175&s=gateway&sprefix=car+hor%2Caps%2C179&sr=8-20-spons&psc=1 Link to comment Share on other sites More sharing options...
ripstik Posted June 28, 2019 Share Posted June 28, 2019 I live in NJ and the weather is crazy hot 100 degrees in summer and cold -15 in winter. Also it rained a bunch here too..water damage on Hella Supertones? Only lasted 2 yrs... smh Sent from my iPhone using Tapatalk .... did you mount them in the grill Link to comment Share on other sites More sharing options...
