fehler1977 Posted January 11, 2021 Share Posted January 11, 2021 Does anyone know where I be causing these tires to have inward camber as seen in this photo? I replace both shocks, both wheel bearings, still nothing Sent from my SM-A015AZ using Tapatalk Link to comment Share on other sites More sharing options...
Pleides Posted January 11, 2021 Share Posted January 11, 2021 Our cars don't come with factory camber adjustment in the rear. Did you or a prior owner perhaps install a Whiteline KTA124 kit? Link to comment Share on other sites More sharing options...
boxkita Posted January 11, 2021 Share Posted January 11, 2021 responded to your other post. if you post multiple times, the solution is still the same Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
fehler1977 Posted January 19, 2021 Author Share Posted January 19, 2021 responded to your other post. if you post multiple times, the solution is still the same Yes sir. Thank you for the heads up. Haha. That was done by accident. I thought that the post add to be deleted but I just had overlooked it Sent from my SM-A015AZ using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted January 19, 2021 Share Posted January 19, 2021 You should be able to delete this post by using the "edit" button and look at the link on the lower right side, I think it is... Might have to use the "go advance" button 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
