crisjp3 Posted June 15, 2017 Share Posted June 15, 2017 Hey Guys I've been wanting to make the shifter crisp again for my car for some time. After doing some reading my understanding is that it's the shifter linkage that needs to be replaced? I was looking at the Kartboy Short Shifter and bushings to add to the package. IS this the solution or am I misreading? Link to comment Share on other sites More sharing options...
Setnev Posted June 15, 2017 Share Posted June 15, 2017 You need to replace the shifter bushing linkage joint. They aren't expensive. You can pick one up on Amazon for around $56 http://amzn.to/2rxEGDY Link to comment Share on other sites More sharing options...
RumbleRumble Posted June 15, 2017 Share Posted June 15, 2017 50$ on ebay for the shifter joint. http://www.ebay.com/itm/Genuine-Subaru-Impreza-WRX-35047AC030-JDM-OEM-Shifter-Bushing-Linkage-Joint-new-/142384258972?hash=item2126c35f9c:g:T90AAOSw3xJVVTh6&vxp=mtr Torque solutions has a good bushing kit too http://www.ebay.com/itm/Torque-Solution-Shifter-Rear-Bushings-Combo-Fits-Subaru-Wrx-2002-2014-Legacy-/142220066315?hash=item211cf9fe0b:g:Wu4AAOSwpdpVVuHg&vxp=mtr Don't get a short shifter. Sucks for DD Depending on where the car is from you bring has to drill out the roll pins for the shifter joint. You can get a new pin from the dealer for like 4$. Link to comment Share on other sites More sharing options...
xrayspecs Posted June 15, 2017 Share Posted June 15, 2017 once you get used to it the short shifter isnt bad if your trans syncros are still new/good... that being said i just swapped out the oem bushings for the full Kartboy kit and it was night and day for the feel/crispness when shifting. the kit i used : https://www.rallysportdirect.com/part/shifter-bushings/kar-kb-003-5comb-kartboy-shifter-bushing-combo I swapped mine with the driveline out of the car so not sure how difficult the roll pins would be to get to with everything under the car. IIRC its a 4mm double roll pin set. Link to comment Share on other sites More sharing options...
RustyRuu Posted June 15, 2017 Share Posted June 15, 2017 If you are doing it in the car try different gears to get a better angle to reach them at 5 th is preferred by most people but it just depends. Link to comment Share on other sites More sharing options...
crisjp3 Posted June 16, 2017 Author Share Posted June 16, 2017 thanks for the info guys! Appreciate it! Link to comment Share on other sites More sharing options...
