subie bob Posted November 15, 2016 Share Posted November 15, 2016 Hey all im having an issue with tire wear my car is eating the rear tires. 6000 miles and they are bald. Its going in to get the alignment checked on Friday. The passenger side went faster than the drivers side and the front tires are still like new. Its even wear across the tire any ideas of what it could be from? It drives straight no pulling except on roads with ruts worn into them. Any ideas are a help thanks Link to comment Share on other sites More sharing options...
whitetiger Posted November 15, 2016 Share Posted November 15, 2016 the alignment will tell the tale. post the before/after printout. Link to comment Share on other sites More sharing options...
quick4dr Posted November 15, 2016 Share Posted November 15, 2016 the alignment will tell the tale. post the before/after printout. LISTEN TO THIS MAN!!! Whitetiger knows every aspect of legacy suspension and dynamics. use his specs and don't settle for anything less! tires are not cheap, good alignment are not cheap Link to comment Share on other sites More sharing options...
subie bob Posted November 16, 2016 Author Share Posted November 16, 2016 This is what the tires look like after 6000 miles first pic is one or the frontothers are of the rear the worst one is the passenger side http://uploads.tapatalk-cdn.com/20161116/2a8b31464b3e64636f45685532a42b93.jpghttp://uploads.tapatalk-cdn.com/20161116/93cd638ce5594ab78d8a3e57bbfedc04.jpghttp://uploads.tapatalk-cdn.com/20161116/cd276979def696a797042ce70466666c.jpg Sent from my SM-N920T using Tapatalk Link to comment Share on other sites More sharing options...
08 LGT Posted November 16, 2016 Share Posted November 16, 2016 Holy shit, I don't think I've ever seen that before. Link to comment Share on other sites More sharing options...
subie bob Posted November 16, 2016 Author Share Posted November 16, 2016 Holy shit, I don't think I've ever seen that before. Ya me either not even on my 427 hp 2wd tacoma i built. From the point of the wear bars making contact with the road to this point was less than 1000 miles Link to comment Share on other sites More sharing options...
08 LGT Posted November 17, 2016 Share Posted November 17, 2016 What's weird to me is that the wear doesn't appear concentrated on one side of the tires like you would expect to see on a bad alignment. Rather, the entire tire is uniformly worn bald. I don't get it. Link to comment Share on other sites More sharing options...
whitetiger Posted November 17, 2016 Share Posted November 17, 2016 if you dont post an alignment sheet, all your pics are meaningless, and any advice is speculation at best. Link to comment Share on other sites More sharing options...
subie bob Posted November 17, 2016 Author Share Posted November 17, 2016 if you dont post an alignment sheet, all your pics are meaningless, and any advice is speculation at best. Goes in tomorrow afternoon for the alignment Link to comment Share on other sites More sharing options...
battelready Posted November 18, 2016 Share Posted November 18, 2016 Well you better be getting new tires with that alignment. I would'nt even be able to attach the laser reflective thing to the tires. I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted November 18, 2016 Share Posted November 18, 2016 I'm very interested in seeing the specs. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted November 18, 2016 Share Posted November 18, 2016 Probably excessive toe in. Link to comment Share on other sites More sharing options...
subie bob Posted November 18, 2016 Author Share Posted November 18, 2016 Here is before http://uploads.tapatalk-cdn.com/20161118/f5581ce1f18b5a216e3635abbb1107ee.jpg Here is after http://uploads.tapatalk-cdn.com/20161118/791de7540997ef2450ddf3875a11bd9f.jpg Sent from my SM-N920T using Tapatalk Link to comment Share on other sites More sharing options...
Rhitter Posted November 18, 2016 Share Posted November 18, 2016 Isn't the total toe still out of the specified range? Or am I reading that wrong? My OBXT build Link to comment Share on other sites More sharing options...
subie bob Posted November 19, 2016 Author Share Posted November 19, 2016 Isn't the total toe still out of the specified range? Or am I reading that wrong? Your reading it right they told me the adjustment was maxed Link to comment Share on other sites More sharing options...
08SpecB_DE Posted November 19, 2016 Share Posted November 19, 2016 Do you have any suspension work done to the car? Adjustable camber kit will fix your issues in the back. They should have brought the camber out in the LF instead of adjusting the toe but that's just me being anal lol. Link to comment Share on other sites More sharing options...
JustCallMeNick Posted November 19, 2016 Share Posted November 19, 2016 LOL so it still needs an alignment? Link to comment Share on other sites More sharing options...
08SpecB_DE Posted November 19, 2016 Share Posted November 19, 2016 Unfortunately, yes it does and hopefully they called him prior to finishing the job. Link to comment Share on other sites More sharing options...
magnusonsubie Posted November 19, 2016 Share Posted November 19, 2016 If thats the best that they could get then something is definitely bent. My car is quite low and every alignment I have gotten they have been able to get my rear toe within spec. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
subie bob Posted November 19, 2016 Author Share Posted November 19, 2016 It was lowered by previous owner and im sure they did it themselves the alignment cam bolts were pretty chewed up from using the wrong size or something. They told me if i could get some kind of kit to help it they would realign it for free since they couldn't get it within spec. Got under it when it was still on the alignment rack couldn't find anything bent or any kind of damage other than the cam bolts. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted November 19, 2016 Share Posted November 19, 2016 It was lowered by previous owner and im sure they did it themselves the alignment cam bolts were pretty chewed up from using the wrong size or something. They told me if i could get some kind of kit to help it they would realign it for free since they couldn't get it within spec. Got under it when it was still on the alignment rack couldn't find anything bent or any kind of damage other than the cam bolts. There ya go! Get the camber eccentric bolts and never wear tires like that again Link to comment Share on other sites More sharing options...
subie bob Posted November 19, 2016 Author Share Posted November 19, 2016 There ya go! Get the camber eccentric bolts and never wear tires like that again Any recommendations on who to get them from? Link to comment Share on other sites More sharing options...
08SpecB_DE Posted November 19, 2016 Share Posted November 19, 2016 Any recommendations on who to get them from? I'm sure any vendor on the site will be able to help. Link to comment Share on other sites More sharing options...
apexi Posted November 20, 2016 Share Posted November 20, 2016 It was lowered by previous owner and im sure they did it themselves the alignment cam bolts were pretty chewed up from using the wrong size or something. They told me if i could get some kind of kit to help it they would realign it for free since they couldn't get it within spec. Got under it when it was still on the alignment rack couldn't find anything bent or any kind of damage other than the cam bolts. I don't know much about alignments, but the last time I had an alignment done was about 45k ago at 160k. The dealer told me that I was lucky my rear was barely in spec, because some adjusting bolts in the back were frozen. So I wonder if maybe your chewed up bolts are what was frozen on my car? Looking at my alignment sheet, I have no idea which bolts they were referring to. I know very little about alignments and suspensions. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted November 20, 2016 Share Posted November 20, 2016 RR camber seems to be your only issue. They could have brought the toe in on the LR just a little bit but again,that's just me being anal. While most say in the green is acceptable, you really want to be as close to center as possible. Link to comment Share on other sites More sharing options...
