The Doctor's '05 White Wagon
I've been meaning to put together a build thread for a while now with how much I've put into this car and how much I've fallen in love with it as my ideal daily driver. I'm not the most proactive when it comes to taking pictures when I make modifications/changes so I'm going to post the majority of pictures that illustrate changes or just random photo's I've taken during the journey. Going forward I hope to be better at documenting changes that involves more than just saving receipts in my rapidly growing binder. So, I've put on NPR's Tiny Desk youtube channel and decided to dive in.
I purchased the car on October 23rd, 2017, in Steep Falls Maine. I had been searching craigslist for the past 2 months not for this particular car, but for a new daily driver in general as my '94 Cadillac Seville had sprung it's second oil leak (half block & head) and I didn't want to put the time/money into it even though the car was in mint condition with only 70k all original miles. ******* Northstar's. I had talked with a few sellers and test drove a few different cars and nothing worked out. Then I came across this beautiful, turbo white wagon with a manual all the way out in Maine :wub:. My gf, now wife, was skeptical becuase I was originally set on getting an EP3 civic for the economy and becuase I wouldn't be driven to modify it which would alllow me to give my S2000 some serious attention. Ended up calling the seller and after some negotiating agreed to buy it sight unseen. The massive amount of dealer maintenance receipts he had from the prior owner helped to take the doubt out of it. Shortly after that call I purchased airline tickets to fly out, pick it up and drive it back ~17hrs to Indiana.
I didn't know at the time that this was a 1 of 49 SWP manual wagon with black interior.....lucky me. It had roughly 146k miles on it when the keys were handed over to me and completely stock with the exception of cut OEM springs, Rota Gravel wheels, grill, and a dealer installed SPT intake.
To make up for lost time I'm not going to list out general maintenance or OEM replacement parts that ocurred during the time of purchase to now. There was quite a few when the car went through the re-paint process (i.e. roof rails).
2005 Subaru Legacy Wagon GT Limited - formerly Satin White Pearl and went through a slight color change to Toyota's Wind Chill Pearl. This can only really be seen and appreciated when the two colors are side by side.
Modifications
"NOC" = not on car
"WIP" = work in progress
Engine
Original Motor - Currently ~179k miles
Fluidampr crank pulley
COBB Short Ram SF Intake w/ Air Box
Grimmspeed Coated TMIC w/ Splitter
IAG AOS v3 (comp) w/ 3MI Drain Hose
Invidia Q300 Exhaust
Grimmspeed Limited Coated Catted Downpipe
Killer B Hard Inlet
SAMCO Black BPV Hose
Silicon Vacuum Lines
TurboSmart Kompact BOV
Grimmspeed 3-port EBCS
Radium Engineering Black Top Feed TGV Deletes
Radium Engineering Fuel Regulator
Radium Engineering Top Feed Fuel Rails & Plumbing Kit & Pulse Dampers
IAG 3mm Phelonic Spacers
ID 1050x Injectors
AEM 340LPH Fuel Pump w/ iWire hard wire kit
Killer B Holy Headers w/ EGT Bung Swain Coated
Killer B V-band Up-pipe Swain Coated
Killer B Aluminum Oil Pan
Killer B Oil Pan Baffle
Killer B Oil Pick-up
IAG Stock Location Oil Feed & AVCS Line
GDT Cylinder 4 Cooling Mod
JMP Custom BNR 18g
GrimmSpeed V2 Coated Turbo Heat Sheild w/ Gold Foil
PTP Turbo Blanket
Koyorad Aluminum Radiator
Killer B Water Pump Housing
ARP 11mm Head Studs
NGK Iridium Spark Plugs One Step Colder
GrimmSpeed 1.1mm head gaskets
GrimmSpeed Exhaust Gaskets - All available/offered
Subaru OEM Engine Gasket Full Reseal Kit
Transmission
SpecB 6spd & R180 Diff
South Bend Clutch Stg3 Daily
ACT Street-Lite Flywheel (Single Mass)
STI Short Throw Linkage
Cobb Adj STS w/ Bushings
GroupN Transmission Mount
Cusco Reinforced Diff Carrier
GoodRidge SS Clutch Line
Torque Solutions Drive Shaft Carrier Bearing
Suspension & Other
Swift Sport Mach Springs
Koni Sport Struts
Perrin 25MM FSB w/ RalliTek Bushings
Cusco 21MM RSB
Cusco Lower Arm Bar Brace Type 1
Cusco Steering Rack Brace
STI 13:1 Steering Rack (15+ STI)
Super Pro Steering Rack Bushings
STI Solid Steering Joint
AVO RSB Brackets
Subaru STI/Group N Top Hats
Super Pro Front Roll Center Kit (KCA313)
Super Pro Bushings & Bolts
- Front LCA (SPF3091K)
- Rear LCA (SPF5112K)
- Front Camber Adj Bolts (SPF4351)
- Rear Diff Mount (SPF3201K)
- Trailing Arm (SPF3388)
- Rear Upper Control Arm - Outward (SPF3389K)
- Rear Upper Control Arm - Inner (SPF3390K)
- Front Crossmember Isolator Mount (SPF3199K)
- Rear Toe Control Arm Outer (SPF3392K)
Kartboy Solid Endlinks Front & Rear
SpecB Aluminum Suspension (all of them)
Powder Coated Subframes F+R
PowerFlex Rear Subframe Bushings
STI Rear Strut Bar
STI Solid Steering Linkage
IAG Street Series Pitch Stop
Whiteline Rear Lateral Link Kit
STI Group N Motor Mounts
STI Flexible Lower Arm Bar & Braces
Prova Rigid Collars F+R
Brakes
Grimmspeed Master Cylinder Brace
GoodRidge SS Brake Lines "NOC"
2011 STI Master Cylinder & Brake Booster "NOC"
tbSTI Rear Backing Plates "NOC"
Rear Brembo Calipers "NOC"
Exterior/Engine Cosmetics
Ceramic Tint "WIP"
Yakima Ridgleline Towers w/ Aero Bars
Subaru OEM Waist Spoiler
Subaru OEM Window Visors
Subaru JDM STI Alcantara Owners Manual Cover
Madrig CF Belt Cover w/ STI logo
Madrig CF ABS Cover
Madrig CF Battery Cover
Madrig CF Air Intake w/ Snorkel
Madrig CF Radiator Cover (works with snorkel)
Madrig CF Grill Surround for Facelift JDM Grill
Madrig Extended Hood Scoop
Madrig Extended Wing
Madrig CF COBB Air Box Lid
Subarua OEM Spats & Strakes
Subaru Grampus Blue Mirror Signals
Subaru JDM Tail Lights
Torque Solutions Black Radiator Stay Brackets
Burger Motorsports Black Slip-On Exhaust Tips for BMW N51/N52
Redline Tuning Hood Struts w/ Carbon Fiber Sleeve
Perrin Brake Reservoir Kozy
Primitive Racing Skid Plate
STI JDM Oil Cap
JDM Facelift Conversion:
- S402 Fenders
- S402 Carbon Fiber Lip
- JDM facelift Spec B bumper & grill w/ Madrig Composites CF surround & emblem
- Custom JDM Blue tint facelift headlights from Circuit Demon
- Morimoto 4TL-R projectors with lens etching of S402 logo over honeycomb background
- Profile Prism RGB Demon Eyes w/ BT controller
- JDM Multi Color Fogs
Interior
Grimmspeed SS Shift Knob w/ Perrin Reverse Lockout
Subtle Solutions WRX/STI Metal Dead Pedal
Dual Vent Gauge Pod
PLX Wideband AFR Gauge
Subaru STI DEFI Gauge Pack
Subaru S402 Door Sills
Subaru OEM Homelink Mirror
JDM Double DIN HVAC
Pioneer AVH-601EX
SVX Adaptor Harness
RAAMmat Sound Deadening (doors, hatch, cargo area)
Full Black Upper Interior Conversion
JDM Door Cards w/ Additional Speaker Grills & black alcantara inserts from Spec B
JDM McIntosh Subwoofer Mount for Cargo Area
JDM McIntosh Mirror Tweeter Housings
JDM McIntosh Center Speaker for dashboard"NOC"
WRX Aluminum Pedals
Dual Center Console Cubby
WeatherTech Floormats Front (COBB Badged) & Rear
2014 OEM Front STI Seats - Driver & Passenger
tbSTI Rear Recling Seats "NOC"
2011 OEM STI Steering Wheel
Red Seat Belts
Redline Goods Shifter & E-brake Boot - Black w/ Red Stiching
08-09 Lower Dash/Console Trim
Lighting
DiodeDynamics TapTurn Flasher Relay
Osram D2S CBB HID Low Beam
LED High Beams
LED Interior Lights
LED Turn Signals - Amber Front & Red Rear
LED Reverse Lights
LED Running Lights
LED Yellow Fog Lights
Wheels/Tires
Enkei Raijin (Gun Metal) 18x8.5 +45
Michelin Pilot Sport A/S 3+ (245/40R18))
McGard STI Lug Nuts
Future Plans In No Specific Order:
6pot/2pot Brembo Brakes - Just need 6 pots and rotors/pads
Upgraded Stereo to Replicate McIntosh Speaker Locations - Upgraded USDM speakers with the addition of (all speaker mounts installed except center speaker):
- Additional tweater on front doors
- Additional 3" mid on front doors
- 8" Rear sub in cargo area
Edited by DoctorDaveLGT
Update parts list
First thing I did with the car is replace the cut springs with Swift's, threw on the Koni struts, and new wheels and tires. Also had a thorough inspection done to get an idea of the general health of the car and had all fluids replaced.
A good buddy of mine liked the wagon so much he decided to join the Subaru family by flying to Florida to pick a up a rare Outback Sedan 3.0 in SWP.
First road trip in the wagon, excluding driving the car back to IN, was to pick up two Shiba Inu puppies in the middle of Missouri. My wife's nickname for the car became "Shibaru".
Few examples of why I bought it. I've also fit and hauled a fully assembled (collapsed) treadmill.
Took off the yellow fog-light film and put on the blue grampus mirrors.
The beginning of the re-paint. A lady backed into the wagon while it was parked in my work lot. I was lucky enough that she went office to office looking for the owner. She hit it with the hitch on her 1500 Silverado and could have totally driven off or parked a few spaces over and I would have had no clue what/who hit it.
Yep, the plan is to run on the stock motor and do the Killer B headers, tgv deletes, ID1050's, and other fuel upgrades all at once rather than piece meal out and pay for several tunes. I'll do another compression & leak down test before everything goes on and then tune conservatively for 325-350ish.
Whenever the motor goes the plan is for an IAG closed deck and basically have an over-built motor that can support 650hp/tq so if I ever get bored I can just upgrade the turbo/injectors or go rotated depending on the power I want. Anything over 450 to the wheels and I probably won't be daily driving it anymore.
  • 2 weeks later...
Nothing currently. I want to see what the fitment of my 245/40s are with less camber before thinking about a wider wheels or tires. If i did go wider, the rear fenders would need some work to accomodate as all the free space is pretty much gone.
Now if only someone could make a drop in rear fender that is wider than stock....that would be very tempting.;)
I swear I've seen it! In his picture thread!
Maybe I've just seen bits of it and the outer quarter of the vehicle removed and just formed the image in my mind. You certainly could do it, it would be a lot like his fender flares, but in some ways easier.
I've been made to understand that outer carbon panels like the m3 roof are more or less glued in where the normal seam welds are. So you adhesive and a lot of clamps. But to pay someone for that! 30+ hours of labor.
  • 3 weeks later...
I think this bumper would look great with your S402 fenders: https://page.auctions.yahoo.co.jp/jp/auction/q344832157
I've been thinking the same thing and been watching it for a while. Don't think I can go through with it though. I bought a facelift spec B bumper from the auctions and the shipping was $1.1k alone :spin:, which at that point I realized I would have been better off buying a front clip from eBay.
I really do think that bumper would look great with everything else.
