njm_t160 Posted September 8, 2013 Share Posted September 8, 2013 Hello, First post How do you adjust the headlights on a 2011 Legacy 2.5?? Mine are badly out of alignment. Thanks, Nels Link to comment Share on other sites More sharing options...
njm_t160 Posted September 9, 2013 Author Share Posted September 9, 2013 Can anyone please tell me the location of the headlight adjusting bolt(s) on my 2011 Legacy? I've tried finding the info with search function and have had no luck. Thanks Nels Link to comment Share on other sites More sharing options...
valkrie hunter Posted September 9, 2013 Share Posted September 9, 2013 taken from another forum: "The adjuster for vertical drivers side is located forward of the battery using an 8 mm (memory so could be 7 mm) socket cw to raise ccw to lower. Pass side you take the air snorkle out to the air filter and you can see the adjuster bolt. The picture shows the adjuster with the housing out off the car. It must be a cadium plated bolt because you can see it fairly well. " Hope this helps... Link to comment Share on other sites More sharing options...
njm_t160 Posted September 9, 2013 Author Share Posted September 9, 2013 Thanks for the info! Exactly what I needed. Is there a horizontal adjustment also? Thanks Again Link to comment Share on other sites More sharing options...
Perscitus Posted September 9, 2013 Share Posted September 9, 2013 No horizontal adjustment (supposedly JDM HID headlights do have it). You can get to both the regular vertical adjustment bolts (LHS and RHS) without removing any parts (except maybe the intake duct) with some extensions. It takes significantly more turning to get the beams to 'budge' than you'd think is needed. Just keep turning. Anyone who is lowered on RCEs and below (say 0.8"+, and especially anything lower than 1.5") would benefit from adjusting the H7s beam back up. Night driving is vastly improved with properly aimed headlights. Link to comment Share on other sites More sharing options...
GTEASER Posted September 9, 2013 Share Posted September 9, 2013 This is something I will have to do before winter sets in and the evenings are dark. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Captain Ned Posted September 9, 2013 Share Posted September 9, 2013 Anyone who is lowered on RCEs and below (say 0.8"+, and especially anything lower than 1.5") would benefit from adjusting the H7s beam back up. Night driving is vastly improved with properly aimed headlights. Thanks, never thought about that. Now off to my private flat spot with wall (actually, the back side of the elementary school just down the street). Link to comment Share on other sites More sharing options...
njm_t160 Posted September 10, 2013 Author Share Posted September 10, 2013 Greetings All, Thanks for all your input. I have checked my lights on a flat surface and the height seems OK, but both headlights are pointing at roughly the same angle of about 30 degrees fom straight ahead. In other words, while my lights are doing a great job of illuminating things that lie off to my left, straight ahead is not so good and worse yet, the right side is almost dark! I have replaced both low beams bulbs recently, so perhaps I installed them wrong?? Is there really no horizontal adjustment? I would like to avoid a trip to the dealer if I could. Thanks, Nels Link to comment Share on other sites More sharing options...
Jay12Legacy Posted September 10, 2013 Share Posted September 10, 2013 makesure the bulbs are clipped in right Link to comment Share on other sites More sharing options...
GTEASER Posted September 10, 2013 Share Posted September 10, 2013 ^^This. Recently someone else had this problem because the bulbs were not reinstalled flush with the housing making them off center. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
njm_t160 Posted September 10, 2013 Author Share Posted September 10, 2013 Thanks for the input . Will check the seating on the bulbs. Thanks again, Nels Link to comment Share on other sites More sharing options...
nicefish Posted October 11, 2017 Share Posted October 11, 2017 ^^This. Recently someone else had this problem because the bulbs were not reinstalled flush with the housing making them off center. Thanks this was my problem after changing the headlight bulb. I was thinking "wow, is this misalignment because the bulb is different from the OEM bulb? Or maybe I messed up the horizontal alignment while trying to get the bulb in there?" Link to comment Share on other sites More sharing options...
nads Posted October 12, 2017 Share Posted October 12, 2017 I found on the passenger side, remove the intake snorkel and look straight down. The hex head of the adjusting bolt is hard to get too but you can use a long flat head screw diver and turn the teeth looking right up at you that are on the adjusting bolt. Just stick the screwdriver in one of the teeth and turn. It will make more sense when you see it. Works on drivers too but you can get a wrench or socket on it. At least this was true for my 14' lights. Can't confirm for 12' and down. Link to comment Share on other sites More sharing options...
