ssulb Posted August 9, 2017 Share Posted August 9, 2017 I ordered the Koni inserts and they are on back order. And this gives me sometime to compare shocks. Bilestein shocks VS Koni??? Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
Humble Rumble Posted August 9, 2017 Share Posted August 9, 2017 From everything I've heard, the Koni's provide a much more comfortable ride while still being ample to use for track if wanted. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
FJuan Posted August 9, 2017 Share Posted August 9, 2017 Koni's My wife's balls are delicious. Link to comment Share on other sites More sharing options...
MilesA Posted August 9, 2017 Share Posted August 9, 2017 I like the Koni Sports, that's what I have on my 4th gen car. Good choice for a daily driver. Bilstein HDs, while a good shock can be harsh on imperfect roads. Link to comment Share on other sites More sharing options...
GTEASER Posted August 9, 2017 Share Posted August 9, 2017 I can't believe the 8610-1453S are backordered again. Did you call Koni directly? There should be another shipment coming before Fall if the one from last April/May is sold out already. Koni now lists the 8610-1447S for fitment from 05 all the way thru 14 Legacy, so you can use those. Are those backordered too? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
ssulb Posted August 9, 2017 Author Share Posted August 9, 2017 Funny thing I should add. Just today I got a message from Koni indicating a problem with my payment. (My bank has a daily withdrawal limit.) So that should indicate that they are actually shipping?? Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
blklgt05 Posted August 9, 2017 Share Posted August 9, 2017 I had both, Koni is comfortable and the car drives well. Bilsteins is still comfortable, but the handling feels much more responsive and better feedback. Bilsteins are not available anymore last I checked, so if you can find it at a good price used, I'd go for that. If not Koni is fine as long as you don't use linear springs. mod journal Link to comment Share on other sites More sharing options...
GTEASER Posted August 9, 2017 Share Posted August 9, 2017 He's in Michigan, probably better to go Koni's to avoid a bad back later in life. LOL! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
ssulb Posted August 11, 2017 Author Share Posted August 11, 2017 I purchased the Konis and I'm going to pair them with a set of RCE springs. I'm definitely going to be happy with them because they are going to be a lot better than my old OEM ones currently. They make the car ride like a 1980s Cadillac. I will also do swaybar upgrades down the road. I do get a slight knock in the front when turning the wheel when I first start driving the car after it has been sitting for a while. I need to investigate that. Do you guys think it is worth it to replace control arm bushings for performance ones and such..? By the way I also found this suspension for the Legacy. http://www.racecompengineering.com/index.php/subaru/2010-legacy-2-5gt-3-6r/suspension/racecomp-engineering-tarmac-zero-coilovers-for-2010-2013-legacy-3-6r-2-5i.html Opinions? Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
GTEASER Posted August 11, 2017 Share Posted August 11, 2017 Those are fantastic. That's what Fred used to run. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
dgoodhue Posted August 11, 2017 Share Posted August 11, 2017 I purchased the Konis and I'm going to pair them with a set of RCE springs. I'm definitely going to be happy with them because they are going to be a lot better than my old OEM ones currently. They make the car ride like a 1980s Cadillac. I will also do swaybar upgrades down the road. I do get a slight knock in the front when turning the wheel when I first start driving the car after it has been sitting for a while. I need to investigate that. Do you guys think it is worth it to replace control arm bushings for performance ones and such..? By the way I also found this suspension for the Legacy. http://www.racecompengineering.com/index.php/subaru/2010-legacy-2-5gt-3-6r/suspension/racecomp-engineering-tarmac-zero-coilovers-for-2010-2013-legacy-3-6r-2-5i.html Opinions? Sent from my SM-G950U using Tapatalk [shameless plug]I will sell you some used RCE springs [/shameless plug] My GT has both of Whiteline front control arms bushings. It is noticeable harsher, but its not horrendous. That being said, I eventually plan to remove my front controls arms and put back in a new set of stock control and bushings. My GT is daily driver and likely I will never track it. Link to comment Share on other sites More sharing options...
Zee199969 Posted August 11, 2017 Share Posted August 11, 2017 I purchased the Konis and I'm going to pair them with a set of RCE springs. I've been running this setup for nearly 30k miles and I'm very happy with it My "Build" Link to comment Share on other sites More sharing options...
GTEASER Posted August 11, 2017 Share Posted August 11, 2017 [shameless plug]I will sell you some used RCE springs [/shameless plug] My GT has both of Whiteline front control arms bushings. It is noticeable harsher, but its not horrendous. That being said, I eventually plan to remove my front controls arms and put back in a new set of stock control and bushings. My GT is daily driver and likely I will never track it. Just the front lower front bushings right? The rear hockey puck bushing don't add to NVH much at all. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
MilesA Posted August 11, 2017 Share Posted August 11, 2017 ...Do you guys think it is worth it to replace control arm bushings for performance ones and such..? To tighten up the steering feel, you don't have to do all of them, IMHO. Maybe the main lower control arm bushings, the sway bar bushings, and the sway bar end links would be enough unless you have other bushings that are worn out. Link to comment Share on other sites More sharing options...
dgoodhue Posted August 11, 2017 Share Posted August 11, 2017 Just the front lower front bushings right? The rear hockey puck bushing don't add to NVH much at all. I didn't realize the rear horizontal bushing didn't contribute much to the NVH. My experience in the past is that it can be sometime hard to press in and out control arm bushings, so I will likely buy new control arms. [subaru also doesn't sell the stock rubber bushings individually anymore] I don't have the proper press to do it, my friend does but he is 2 hours away so its logistically more difficult for a daily driver if run into any issues. I am not doing it right now anyways. I am done spending money on my GT unless absolutely necessary until I sell my 2.5i. Link to comment Share on other sites More sharing options...
GTEASER Posted August 11, 2017 Share Posted August 11, 2017 Don't sell 2.5i yet. Use 2.5i to drive 2 hours to visit friend to press bushings while GT on jackstands. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
ssulb Posted August 12, 2017 Author Share Posted August 12, 2017 [shameless plug]I will sell you some used RCE springs [/shameless plug] Sure I would be interested. I'll PM you. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
Syndicate Posted August 12, 2017 Share Posted August 12, 2017 ...I'm a Bilstein fan, the ride is firm but not harsh. Paired w/Swift springs and a Whiteline RSB I don't have many handling wants. Link to comment Share on other sites More sharing options...
MilesA Posted August 12, 2017 Share Posted August 12, 2017 ...I'm a Bilstein fan, the ride is firm but not harsh...The OP is in Michigan, basically like driving on the surface of the Moon. Link to comment Share on other sites More sharing options...
ssulb Posted August 12, 2017 Author Share Posted August 12, 2017 I wish I could get the Bilestein or the KW but a little too expensive for me. I'm a college student and Konis would be amazing enough. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
GTEASER Posted August 14, 2017 Share Posted August 14, 2017 I wish I could get the Bilestein or the KW but a little too expensive for me. I'm a college student and Konis would be amazing enough. Sent from my SM-G950U using Tapatalk Did you see the ones for sale in the classifieds? Pretty much the same price as Koni's. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
ssulb Posted August 17, 2017 Author Share Posted August 17, 2017 Did you see the ones for sale in the classifieds? Pretty much the same price as Koni's. I could any shock absorbs on the classified. I found a Gekco set but the posting is very old and the person didn't respond yet. Link to comment Share on other sites More sharing options...
GTEASER Posted August 17, 2017 Share Posted August 17, 2017 They just sold today. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
ssulb Posted August 17, 2017 Author Share Posted August 17, 2017 They just sold today. [emoji17] [emoji24] Oh well, Konis it is. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
crankshift Posted August 17, 2017 Share Posted August 17, 2017 just installed konis recently too and I get that knock sound up front when I turn out of the driveway or something like that at slow speed when I first get in.. I believe we are supposed to reuse an oem washer on each front as well as the new koni washer on each... one of these washers has a specific orientation (either up or down) and Im going to have to confirm that was done right as well I purchased the Konis and I'm going to pair them with a set of RCE springs. I'm definitely going to be happy with them because they are going to be a lot better than my old OEM ones currently. They make the car ride like a 1980s Cadillac. I will also do swaybar upgrades down the road. I do get a slight knock in the front when turning the wheel when I first start driving the car after it has been sitting for a while. I need to investigate that. Do you guys think it is worth it to replace control arm bushings for performance ones and such..? By the way I also found this suspension for the Legacy. http://www.racecompengineering.com/index.php/subaru/2010-legacy-2-5gt-3-6r/suspension/racecomp-engineering-tarmac-zero-coilovers-for-2010-2013-legacy-3-6r-2-5i.html Opinions? Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
