Mill Posted April 30, 2013 Share Posted April 30, 2013 Today the car went into limp mode and wont boost past 7psi. Opened up learning view and had a few wastegate duty codes (dont remember what the exact codes were because I reset them). I reset the ECU and now my IAM is 0.00 and I have a misfire code for cylinder 1 as well as a p0000 code. Before I reset the ecu the IAM was .12xx which I know is also bad. My learning view log is attached. My boost gauge tells me I have a slight vac leak but its a prosport so I dont know how accurate it is. Any ideas? Stage 2 3 port ebcs 5eat FMIC RomRaider Log: https://docs.google.com/spreadsheet/ccc?key=0AmSSmnMMJty8dFNaZXpzalhXcWNYT2wwLW9UdTJiWkE&usp=sharing Link to comment Share on other sites More sharing options...
Mill Posted May 2, 2013 Author Share Posted May 2, 2013 Got some additional codes. Trying to take a romraider log but the laptop died so I am awaiting it to charge. Bad 02 sensor? p1518 - Starter Switch Low Input p1152 - Front 02 Sensor Range/Perf Low B1 S1 p1153 - Front 02 Sensor Range/perf High B1 S1 Still not boosting past 7psi. I am staying out of boost in the meantime to play it safe. Link to comment Share on other sites More sharing options...
CapSlo Posted May 2, 2013 Share Posted May 2, 2013 Bad 02 sensor? I'd start with that. Link to comment Share on other sites More sharing options...
Mill Posted May 2, 2013 Author Share Posted May 2, 2013 Ok. I'll start with that. In the meantime, here is the log: https://docs.google.com/spreadsheet/ccc?key=0AmSSmnMMJty8dFNaZXpzalhXcWNYT2wwLW9UdTJiWkE&usp=sharing Sorry for the size. Didn't have time to edit out the crap yet. Link to comment Share on other sites More sharing options...
cryo Posted May 4, 2013 Share Posted May 4, 2013 Did you pull that second lv with the test connectors still hooked up? Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
Mill Posted May 6, 2013 Author Share Posted May 6, 2013 Now that I think about it I pulled both with the connectors hooked up. That would explain some of those codes. Car is boosting now and I didn't do anything to it. Ordered some exhaust gaskets to fix some leaks and I am going to test for boost leaks once finals are over. Link to comment Share on other sites More sharing options...
