ctfinest28 Posted July 2, 2014 Share Posted July 2, 2014 Hi guys I am trying to install the passenger side ocv. I have gotten as far as to taking the old one out but for some reason the new one isn't going right in. Can anyone give me any suggestions. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 2, 2014 Share Posted July 2, 2014 You have a 2005 for those that don't know, may be add that to your info under your screen name. If you have the right part it should slide right in. Can you re-install the old one ? Did you put some oil on the seal ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ctfinest28 Posted July 2, 2014 Author Share Posted July 2, 2014 This is the right part did the driver side Link to comment Share on other sites More sharing options...
ctfinest28 Posted July 2, 2014 Author Share Posted July 2, 2014 Just tried sliding in the old piece and it did not fit Link to comment Share on other sites More sharing options...
Max Capacity Posted July 2, 2014 Share Posted July 2, 2014 I guess by now you have placed both parts next to each other and compared them ? How hard is it to pull the other side out and try it in this side ? I know you realize it has to fit... can you look inside the bore, take a picture of the bore ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
apexi Posted July 2, 2014 Share Posted July 2, 2014 I'm sure you may have tried twisting the OCV, but it looks like the OCV bracket is facing the side in your picture, and based off of other pictures I've seen it looks like the bracket should be going straight up. Link to comment Share on other sites More sharing options...
ctfinest28 Posted July 2, 2014 Author Share Posted July 2, 2014 I did both ways it seems like there is something blocking it from entering Link to comment Share on other sites More sharing options...
m sprank Posted July 3, 2014 Share Posted July 3, 2014 Could be as simple as greasing the o-ring. If the old one came out... Link to comment Share on other sites More sharing options...
ctfinest28 Posted July 3, 2014 Author Share Posted July 3, 2014 It seems like the piece of metal next to it is blocking it from going back in Link to comment Share on other sites More sharing options...
gear_monkey Posted July 3, 2014 Share Posted July 3, 2014 I had to slightly bend that metal bracket that is in the way(the turbo coolant tank bracket) towards the driver side. Once I slid the ocv past it, I just bent it back into place to put the coolant tank back in place. Link to comment Share on other sites More sharing options...
ctfinest28 Posted July 3, 2014 Author Share Posted July 3, 2014 Thanks I was looking to fake it off, but couldn't find how to. What did you bend it with btw? Link to comment Share on other sites More sharing options...
ctfinest28 Posted July 3, 2014 Author Share Posted July 3, 2014 *take Link to comment Share on other sites More sharing options...
rob-2 Posted July 3, 2014 Share Posted July 3, 2014 Had to force mine back in. Link to comment Share on other sites More sharing options...
ctfinest28 Posted July 3, 2014 Author Share Posted July 3, 2014 Figured it out last night with my cousin. We had to grab an extender and place it behind the ocv then slowly hammer it in. What a PITA to figure out Link to comment Share on other sites More sharing options...
Max Capacity Posted July 3, 2014 Share Posted July 3, 2014 LOL yea, you would never think you had to hammer it in...stupid subaru... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
