sd2180 Posted April 8, 2020 Share Posted April 8, 2020 Quick question guys. I have a 05 OBXT and my donor car is an 06 LGT. The LGT has Kartboy endlinks and I was just curious if they are a direct swap-over part. They were on the car less than 10k miles and I was going to buy the rebuild kit if they are a go to save some money. Link to comment Share on other sites More sharing options...
Pleides Posted April 8, 2020 Share Posted April 8, 2020 (edited) Yes, they should fit. Edit: woops, maybe not, was looking at sway bar compatibility between the models. I can't see why they wouldn't but you'd wanna contact kartboy or the like. I would think you'd need a lowered set of suspension on your Outback to make it work. Edited April 8, 2020 by Pleides Link to comment Share on other sites More sharing options...
sd2180 Posted April 8, 2020 Author Share Posted April 8, 2020 Yes, they should fit. Edit: woops, maybe not, was looking at sway bar compatibility between the models. I can't see why they wouldn't but you'd wanna contact kartboy or the like. I would think you'd need a lowered set of suspension on your Outback to make it work. Alright thanks I’ll have to look into it a little more. The LGT does has lowered suspension but I wanted to keep mine higher due to some of the job sites I work on having shitty access roads. Link to comment Share on other sites More sharing options...
Yasha Posted April 19, 2020 Share Posted April 19, 2020 Can confirm that the kartboy endlinks work on the outbacks. The rear on my car was a PIA to install but I got them in eventually. Link to comment Share on other sites More sharing options...
