LateToTheParty Posted May 3, 2021 Share Posted May 3, 2021 Was driving early and noticed that my high beam indicator is dimly lit when the low beams are on. When I turn on the high beams they become fully lit. I have been driving at night for a while now and it just happened earlier. Any ideas what might cause it? It LB and HB work as they should, its just the indicator at the dash. Change bulbs? The bulbs are almost 2 years old and I think these are supposed to last for 300hrs only. Link to comment Share on other sites More sharing options...
doublechaz Posted May 3, 2021 Share Posted May 3, 2021 Check grounds. Also, with car and lights off switch high-low about 50 times to make sure the switch internals are clean of tarnish. But probably the grounds. Link to comment Share on other sites More sharing options...
