Shogun506 Posted August 23, 2019 Share Posted August 23, 2019 So just a quick question regarding lowering an OBXT to Legacy height or an inch or so lower (not slammed by any means). Can I do this just by removing the struts and installing coilovers or is there a lot more required? I see if you go with the struts and springs method it seems to be a lot more involved but can I just swap in some BC coilovers and be done with it (and achieve proper alignment)? I was originally looking for an LGT wagon but there's a nice OBXT that popped up around here and I'm considering buying it and lowering it instead and I'd like to get an idea of the work involved. Link to comment Share on other sites More sharing options...
Keyan Posted August 23, 2019 Share Posted August 23, 2019 you can just install coils. Link to comment Share on other sites More sharing options...
Rhitter Posted August 25, 2019 Share Posted August 25, 2019 A decent amount more. Coils will not give you waht you need to correct rear camber + you will be riding on the Outback bumps stops If you get the extended height coilovers (allow you to go an inch or so lower that a stock outback) or put strut spacers on top of normal coilovers you should be fine. Once you get to around Legacy height you need to start thinking about rear camber. My OBXT build Link to comment Share on other sites More sharing options...
Register a new accountSign in
