bermo's build
My problems started with random misfire codes alternating between #1 and #4, they popped while cruising up an incline in 4th at maybe 2psi of boost. Car appeared to run fine, so, brilliant me just cleared the codes.
My problem got worse when the code would not clear for more that a minute or so, and the car was obviously missing, running on 3 cylinders.
Barely running.
Got it home and it pretty much died when my foot came off the pedal. She was shaking really bad. Pulled the #1 plug.
Got a new plug in it and it ran fine without misfires but it had a hollow thumping sound coming from #1. The filler tube had pretty good pulses. Pulled the new #1 plug back out and it was covered in oil. #4 plug looks fine.
Decision has been made to pull it.
Here are the plugs:
Here is my direction:
• Bore and hone existing block to 99.75mm
• Mahle 4032 pistons
• Brian Crower bRod's
• New OEM 257 crank
• New SixStarSpeed 30-XR
• New OEM gaskets
• New OEM water pump (...026)
• New Busted Finger TGV delete
• ARP 2000 head studs
• Gates TCK328
• Killer B pick up and baffle
• GrimmSpeed TMIC
• Meth Inj
The oil looks good so far although it smelled like gas. I'll know more when I drop the pan.
• Re-use oil pump if pan is clean
• Re-use oil cooler is pan is clean
Got her pulled this weekend, used the 2 point method with the alternator bracket.
Opened the filter and found some gold.
Sitting on the stand now, trying to figure out a leak down test without a compressor, former bike guy here so its the bike pump kinda thing.
The trans is doing just fine, but boy its a head snapper when cold!
I was already planning on doing this but it came up quicker than I wanted, just gonna move forward with it.
Well, the car is paid for. 97K miles, not really daily driven. Hoping to do some autocross or track days with my 3 year old when he gets older.
I got cash put aside for this because I knew it was coming, I just thought it would be a bit longer.
For me, in my situation, it is cheaper to rebuild the motor than to start all over with an unknown car. I got money into in other areas and I kinda love the car.
-JB
Looks simaliar to my build with my spare block. Might want to look into better bearings since your rebuilding IE king or cosworth.
Good luck
Plan is to use King Bearings or Clevite, and Cossie, well... that just sounds expensive.:wub:
Are you doing 4032 or 2618 pistons?? Tight or loose on the PTW? Mahle 4032 wants something like .0021 - .0029 and I'm gonna try and keep it on the tight side.
Still looking for a used torque plate for the bore and hone, I thought there would be a few floating around from the one timers.
I may just buy a new one and then rent it out to some LGT guys??
-JB
King bearings are the best for the money then cossie. Clevite is having issues with clearances being different.
I'm doing 4032 If i stay under the 450whp mahle above cosworth.
Clearances are going to be tight since i am not going for to much power. i want to be in the daily driven 400whp with a turbo set for low boost. I want to see how long a setup like this can last. Bren has a ralispec motor with over 100k on it and they run 4032 or cosworth in their street motors.
2618 is designed for a motor that will be re ringed regularly.
... Bren has a ralispec motor with over 100k on it and they run 4032 or cosworth in their street motors.
How about rods? They needed at the 400whp range?
Wonder if Rallispec used a torque plate for the bore and hone?
Trying to figure if its worth the hassle and cash, I need all the tricks I can get.
OEM rods are fine for 400whp but if your making lots of low end torque get a set decent rods. as for a specific brand i haven't decided. HP can destroy rods but torque is what bends them.
I guarantee they use a torque plate like 100%of the other professional engine builders.
Might be a question of if you have a subaru builder in the area that can machine your block since they already have the tools and know the clearances.
Also getting the rotating assembly balanced even though it is "naturally Balanced" it will make for a smoother running motor.
Got some rods on the way.
My "local" builder sends his blocks down to Seattle, that is not an option for me.
The plan is taking my block to work, decking it, boring it with a torque plate and then taking it to my buddies shop for the hone. He builds and races Mopars and I'm confident he can hit a number, I just gotta figure out what number.
Looks like I'm going to buy a brand new torque plate, can't find a used one. Ugh.
Got a balance shop lined up. $200 for a component balance, money well spent.
-257 crank arrived
-New water pump (…026 cast impeller) arrived
-List of hoses gathered
-bRods ordered (great price from Sprank BTW)
-Need to commit on pistons Mahle or Woosner 4032
-Need to bite the bullet on a new 10mm pump and oil cooler
-Need to order King bearings
-JB
  • 2 weeks later...
• Pulled valve covers off and looked at the cams, I don't really know if they look good or not. You can see on the top of the lobe some wear, but you can't really feel it.
• Fuel rail pulsation dampener looks like it has been leaking, gonna replace both.
• Got 3 of the 4 cam bolts loose by hand with a breaker bar and some nice cam wrenches. The 4th should come off with a rattle gun but it was too late last night and I didn't want to wake the kid.
• Will pull intake and heads tonight, hopefully. Going to see if the Harbor Freight Leak Down Tester will work with my Schrader valve set up.
• Any idea on what that vac line off the intake is, with the rotten foam?
What oil were you using ? the heads and cams look very dark compared to others.
Not sure I'd waste money on a leak down tester at this point. Just use that money towards the head rebuild.
Engine Build - Click Here
Rotella 5W-40 changed ~3K, car only does 6-7K a year.
Leak down may be a waste of time at this point, just curious to compare the results to what I find.
After getting 3 of the 4 cam bolts out with a breaker bar, the 4th bolt gave a little fight. This #12 Craftsmen extractor and a battery impact did the trick. 26mm or 1" socket to drive the extractor.
Separated the block, I used a 3/4" brass drift through the access hole and then through the rod. Turned the crank and she came apart pretty easy.
All cylinders have good crosshatch except for #1, couple good grooves in it. Haven't had a chance to measure yet. Hoping a good hone might get it.
Crank and mains look good. Had .003" thrust on the crank.
Machine shop closes early on Friday so I didn't get a chance to talk to him about the heads. Not sure what I'm going to do there.
Want to buy my worked heads with kelford stg2 cams?
Prolly too much head for a 55lb/min turbo, but would like more info. Email or PM should be fine Josh. Thanks.
My heads are going in the shop today for an estimate, I think the pulverized ring land bent the valves so I'm expecting the worst.
-Mahle 4032 99.75mm ordered :)
