Ninjacheezit Posted June 5, 2020 Share Posted June 5, 2020 (edited) So I’m doing an auto to manual swap on my 07 legacy. Putting the wires back in I have some unused any idea where any of these belong? And there is no wire that goes to my parking brake my brake light is on. Only decided to do this since my transmission was going and I thought it would be fun. Not practical I know but it’s a project. Edited June 5, 2020 by Ninjacheezit Link to comment Share on other sites More sharing options...
rhino6303 Posted June 5, 2020 Share Posted June 5, 2020 In image 3, that connector is for the cigarette lighter harness under the stereo. If you post images with a little more background of where the connector is and then the detailed connector, it may give me a better idea. I think one other is for the radio antenna but I need a me more general location, etc to know for sure. Maybe make alone post per connector with one general location/harness image and one specific image. Link to comment Share on other sites More sharing options...
Ninjacheezit Posted June 5, 2020 Author Share Posted June 5, 2020 Okay ya I can get some better pics after work. I can give you some idea where they are. Image 1 is right by the fuse box. Image 2 well that’s the parking brake lol image 3 is part of the wires in the center console. Image 4 is inside a cut out under the driver dash to the left. Image 5 is attached to the transmission well runs under the carpet this was part of my 07 not sure if it’s on the 05. Image 6 is attached to the radio wires looks like the parking brake wire but way too short? Image 7 is hanging to left of the steering shaft by the black box mounted on it. Image 8 is taped down on the wires going to the relay under the dash Link to comment Share on other sites More sharing options...
Max Capacity Posted June 5, 2020 Share Posted June 5, 2020 I seem to recall that pink one is for Sat radio. Also Dave Brady was the first guy to do this, he still works at ESP in Sterling MA. http://www.enhancedstreetperformance.com/ I think there are other threads on here about doing this too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Ninjacheezit Posted June 5, 2020 Author Share Posted June 5, 2020 Okay so this one could very well be the cig lighter connector it’s weird that the 07 has a different plug for this if that is the case Link to comment Share on other sites More sharing options...
Ninjacheezit Posted June 5, 2020 Author Share Posted June 5, 2020 ? Link to comment Share on other sites More sharing options...
Ninjacheezit Posted June 5, 2020 Author Share Posted June 5, 2020 This one is a left over open connector from the 07 body harness. The 05 didn’t have anything matching this. Link to comment Share on other sites More sharing options...
Ninjacheezit Posted June 5, 2020 Author Share Posted June 5, 2020 So the 07 had a single wire going from the radio area to the e brake. On this harness I don’t see anything. I also can’t get my brake light to turn off so I’m assuming the car thinks it’s on. How does the 05 manual gt have it hooked up? Link to comment Share on other sites More sharing options...
Ninjacheezit Posted June 8, 2020 Author Share Posted June 8, 2020 Bump still nothing on these connectors. Spent the day struggling with the rear diff bolts but finally got the manual diff in. Link to comment Share on other sites More sharing options...
DaveWaters Posted June 8, 2020 Share Posted June 8, 2020 For your wiring issues, have you checked the vacation pics yet? http:// http://people.csail.mit.edu/ilh/vacation/ Link to comment Share on other sites More sharing options...
Ninjacheezit Posted June 8, 2020 Author Share Posted June 8, 2020 Thanks for thats! Did not take a look at it but I did now. This should help me trace the brake switch wire. Sadly got to wait until the morning. As for the other connectors it would be luck trying to find those things in all these pages unless I notice something else not working Link to comment Share on other sites More sharing options...
