Mini DIY Ashtray to Storage tray light
I don't know if anyone even needs a guide for this but since I was going to be doing this for myself, I mind as well document it.
So this guide is how to relocate the OEM ashtray light up to the tray that is above/below the stereo head unit.
It's a really simple modification, only took about 20 minutes and you will not have to do any wiring or other modifications to the car.
Materials Required
-Sheet of Lexan Polycarbonate (preferably 1/32 thick) or comparative clear material
-Clear RTV or some clear hardening silicone
-74-CWHP3 LED bulb (if you want to convert to LED)
Cost to Build
$3.49 LED
$7.50 Lexan Sheeting
+ $1.00 Blue Tint (Blue LED would have worked too)
$11.99
DIY Guide for Foot well lights
http://legacygt.com/forums/showthrea....html?t=253431
DIY Guide for HVAC Color Change
http://legacygt.com/forums/showthread.php?t=251981
DIY Guide for Underhood light
http://legacygt.com/forums/showthrea....html?t=259451
http://i1317.photobucket.com/albums/t637/96Brighton/Tray%20Light%201_zpsf0lhnqeb.jpg
Trace the OEM bulb housing in the location you want it on the top of the. stereo tray. Then carefully cut it out.
http://i1317.photobucket.com/albums/t637/96Brighton/Tray%20Light%203_zpsfujjefoy.jpg
OPTIONAL Cut out or remove the original area the screw attached to
http://i1317.photobucket.com/albums/t637/96Brighton/Tray%20Light%204_zpshq6i4lag.jpg
http://i1317.photobucket.com/albums/t637/96Brighton/Tray%20Light%205_zpsfyitt2id.jpg
Cut a small section of lexan sheet and hold it over the hole and trace the hole, then cut and trim the lexan to fit snuggly in the hole. Then once it's where you are happy with it, us a dental pick or small tool, apply a very small amount of RTV around the perimeter of the mating surface of the lexan and tray. Use the Qtip to carefully remove extra glue without smearing it onto the lexan lens
http://i1317.photobucket.com/albums/t637/96Brighton/Tray%20Light%207_zpsawxpdylq.jpg
http://i1317.photobucket.com/albums/t637/96Brighton/Tray%20Light%2010_zpslqhyaznv.jpg
http://i1317.photobucket.com/albums/t637/96Brighton/Tray%20Light%2011_zps6rafapif.jpg
Clean up the extra glue and then glue the bulb housing to the top of the tray and let cure for however long your glue says.
http://i1317.photobucket.com/albums/t637/96Brighton/Tray%20Light%2012_zpsyckf186n.jpg
Pro tip: DO NOT use super glue, it'll ruin the lexan
http://i1317.photobucket.com/albums/t637/96Brighton/Tray%20Light%208_zpsemnrmxkh.jpg
I will have pictures of it installed soon.
I just ordered t3 twist bulbs that are a single LED. The come in blue, so you could swap those into the HVAC. Not sure how the eblue would look through the green tint, you may need to try that route!
I actually just took apart my spare HVAC unit and did the whole blue conversion for the DIY, there are actually just little light bulbs and they are soldered in very simply to the board, so I'm going to install it tomorrow and see if I like it, if not then I'll run over to radioshack and pick up some white or blue LEDS.
