Gauge options
So does anyone really run gauges in their Legacy? I understand that a Cobb pretty much serves display needs but I'm just not cool with having the unit always on display next to my window. But I also don't want the Leggy looking ricey.
Has anyone given something like this a try? Not too prominent, it's subtle, and looks like it flows nicely.
http://www.ortizcustompods.com/subaru.html
Ortiz makes one for just about every car. They use the OEM gauge visor bezel, add the gauge pods and refinish the entire piece. They are very nice, but you have to wait several weeks after ordering because they do everything custom by hand. I have one in my Forester and it's far nicer than the SYM pod available. They are pretty much our only option for gauge pods besides the goofy ET neck/head vent pod by Block8Head.
The custom mounted pod I made for the boost gauge in my GT is in my build thread. I also had one sitting around and put one just like it on my GT.
Check out http://www.veisystems.com for some cool LED display gauges. I am in the process of installing their D1 series gauges in the Fozz. I will have 3 gauges displaying 6 different monitors, Boost/AFR, coolant/trans temp, oil press/oil temp.
I have a dual gauge vent pod and it doesn't look too bad. The only thing I'm not happy about is the difference between the AP & the boost gauge. Sometimes they are off by up to 1.2 psi. In the future I may jump into multi sensor gauges since I really don't need a dedicated Boost gauge if it's not going to be close to what the ECU is seeing.
What's the difference between the boost and boost (high resolution) gauge options?
  • 2 weeks later...
Welp, just ordered the orbits and an aem boost gauge. I'm going to get the aem wideband too along time the pod gets here. But of course that means I'm going to have to drop the Nameless dp again to get an O2 bung welded in because they filled the order without welding that in (mine was one of the ones that was supposed to have it on). Guess we'll see in 5 weeks 🤣
Sent from my SM-G935V using Tapatalk
Welp, just ordered the orbits and an aem boost gauge. I'm going to get the aem wideband too along time the pod gets here. But of course that means I'm going to have to drop the Nameless dp again to get an O2 bung welded in because they filled the order without welding that in (mine was one of the ones that was supposed to have it on). Guess we'll see in 5 weeks ��
You were supposed to send it back to them to add the bung. They screwed up and forgot the extra bung so they did this for everyone and ate the return shipping and shipping to resend the it to us with the added bung.
http://legacygt.com/forums/showpost.php?p=5266210&postcount=284
