OPoo321 Posted April 1, 2021 Share Posted April 1, 2021 So I have read over every post and sticky and my head is swimming I am confused... And befuddled..I posted late last year and now getting to this I have a 2011 3.6R Limited with now 95K Sway bars are settled.... Is there not a simple, plug and play suspension swap? I dont wanna lower my car. Im arthritic. Its low enough... I just wanna ditch the buick like handling.. And like now. Its parked until i figure this out.. Ill let my ass hurt from the awful seat in my mini until then or drive the boring Acura TIA and yes I am sure i missed something. I am sorry for asking something obvious but I sure as hell dont see it Link to comment Share on other sites More sharing options...
OPoo321 Posted April 1, 2021 Author Share Posted April 1, 2021 (edited) What ive come up with FYI ( i think) 2014 Legacy Springs (all 4 corners) Either Koni or KYBS 26 MM Front Sway Bar (orderd) 20 MM Rear Sway Bar (orderd) Edited April 1, 2021 by OPoo321 Link to comment Share on other sites More sharing options...
Plastixx Posted April 1, 2021 Share Posted April 1, 2021 In your case, I would just go with KYB. Make sure you get the 13-14 struts. Link to comment Share on other sites More sharing options...
creep_nu Posted April 1, 2021 Share Posted April 1, 2021 nobody really makes quick struts for these cars, so the drop in is a little more involved, but like the others have said the upgrade to 13/14 struts and springs should make a solid difference Link to comment Share on other sites More sharing options...
Sarang Posted April 2, 2021 Share Posted April 2, 2021 You are correct. I put 2013 oem springs with KTB struts on my 2010. It made it WAY better, like the car should have come from the factory. Link to comment Share on other sites More sharing options...
DrD123 Posted April 3, 2021 Share Posted April 3, 2021 Well, Konis are great, but it's not a simple install (you need to either get donor struts and cut them to install the Koni dampers or pull yours and do it, or find a shop that will do it for you) - I believe there is a Cusco option someone posted about. Not sure what other aftermarket options there are for the 5th gen. If you go for OEM-like, then the 13-14 KYB struts that have been suggested are a good option. It depends on what your goal is performance-wise. if you just want it firm things up a bit, 13-14 springs and struts, along with the swaybars will be pretty transformational on how the car rides. Link to comment Share on other sites More sharing options...
ssulb Posted April 5, 2021 Share Posted April 5, 2021 Not sure what the typical lifespan of Konis are but I am at 80k with mine installed. They have been very noisy for the past 20k. I checked that bottom bolt and it's torqued down. I have them paired with RCE blacks. Link to comment Share on other sites More sharing options...
DrD123 Posted April 6, 2021 Share Posted April 6, 2021 I believe they do lifetime rebuilds/replacements - if they seem like they are failing, and you're using the ones Koni calls out for your car (so 8610-1447 Sport inserts in front and 8010-1055 Sport shocks in the rear) I'd reach out to them. (they pretty specifically state if its anything other than the ones they specify for your car, you are sol, though) Link to comment Share on other sites More sharing options...
dgoodhue Posted April 6, 2021 Share Posted April 6, 2021 Not sure what the typical lifespan of Konis are but I am at 80k with mine installed. They have been very noisy for the past 20k. I checked that bottom bolt and it's torqued down. I have them paired with RCE blacks. I have about 50K miles on my Koni's paired with Eibachs and they still seem fine. Link to comment Share on other sites More sharing options...
motorbreath Posted April 6, 2021 Share Posted April 6, 2021 You are correct. I put 2013 oem springs with KTB struts on my 2010. It made it WAY better, like the car should have come from the factory. Did the same with my 2010, rides great for a daily driver. Link to comment Share on other sites More sharing options...
ssulb Posted April 7, 2021 Share Posted April 7, 2021 I believe they do lifetime rebuilds/replacements - if they seem like they are failing, and you're using the ones Koni calls out for your car (so 8610-1447 Sport inserts in front and 8010-1055 Sport shocks in the rear) I'd reach out to them. (they pretty specifically state if its anything other than the ones they specify for your car, you are sol, though) Oh yeah. I forgot about the warranty. That's also something to keep in mind while selecting suspension. To be honest I love my Koni setup. It's a good mix for daily driving and sportiness. Took it autocrossing and they were great. Link to comment Share on other sites More sharing options...
copyboy311 Posted April 8, 2021 Share Posted April 8, 2021 (edited) Did the same with my 2010, rides great for a daily driver. If I'm replacing all four corners on my 2011, do I also put the 2013-14 spec rear shocks on? And in the case of the KYBs you're buying the springs from the dealer? RockAuto does show a quick-mount setup available. From FCS? Edited April 8, 2021 by copyboy311 more info Link to comment Share on other sites More sharing options...
motorbreath Posted April 8, 2021 Share Posted April 8, 2021 If I'm replacing all four corners on my 2011, do I also put the 2013-14 spec rear shocks on? And in the case of the KYBs you're buying the springs from the dealer? RockAuto does show a quick-mount setup available. From FCS? I got the 13-14 springs from the dealer, quite cheap, but a long wait, 20380AJ10A (front) and 20330AJ10A (rear) and KYB everything else for 13-14. I did end up needing 1" spacers for the rear for some reason, but most people did not. Link to comment Share on other sites More sharing options...
copyboy311 Posted April 9, 2021 Share Posted April 9, 2021 (edited) Does anyone have any feedback or opinions on this quick-strut kit from FCS? https://www.rockauto.com/en/moreinfo.php?pk=8556948&cc=1446525&jsn=845&jsn=845 Edited April 9, 2021 by copyboy311 Link to comment Share on other sites More sharing options...
Plastixx Posted April 9, 2021 Share Posted April 9, 2021 Does anyone have any feedback or opinions on this quick-strut kit from FCS? https://www.rockauto.com/en/moreinfo.php?pk=8556948&cc=1446525&jsn=845&jsn=845 It is what it is, a budget option that's better than blown factory struts. I only see them as an option if you're really strapped for cash and desperately need to replace worn struts. Otherwise, just go with KYB. Link to comment Share on other sites More sharing options...
creep_nu Posted April 9, 2021 Share Posted April 9, 2021 yup, i'd only get those for a flip car or something you don't plan to keep for many miles Link to comment Share on other sites More sharing options...
copyboy311 Posted April 13, 2021 Share Posted April 13, 2021 Besides the struts and springs up front, are there any other suspension or steering bits in the front that I should consider? Some of the bushings look pretty dried out and useless, but I'm not sure which bushings they are. Link to comment Share on other sites More sharing options...
creep_nu Posted April 13, 2021 Share Posted April 13, 2021 if it were me i'd go ahead and just replace the control arms while you're in there. you can go OEM, or you can get mevotech supremes which have uprated but not overly stiff bushings...both options come with new ball joints IIRC. if you're doing the control arms you might as well do the sway bar links since you're already half way to changing them when removing the control arm. inspect the tie rods and replace if necessary since you're going to need an alignment anyways. Link to comment Share on other sites More sharing options...
Scubaboo Posted April 13, 2021 Share Posted April 13, 2021 If you are doing struts, I'd do the strut mounts too. If any bushing looks suspect, I suggest doing them all including the ball joint with OE parts, or getting a whole arm assembly like the Mevotechs. If you are doing front sways, which from what I read includes dropping the subframe, I'd do the steering rack bushes while I'm there. That would also be a good time to do motor mounts. Link to comment Share on other sites More sharing options...
