11boostedgt Posted February 10, 2021 Share Posted February 10, 2021 had anyone here had to replace the studs on the vf54 turbo? i need to do my timing belt and water pump and i know i have to remove the cat/j-pipe to do it. the nuts holding it on are about as bad as it gets and i have a feeling i will have to replace the studs while in in there. my questions are... 1. how the hell can i get the nuts off that pretty much have no sides to them? 2. any one replace there studs with a aftermarket kit like grimmspeed? or am i stuck getting them from Subaru? Link to comment Share on other sites More sharing options...
stewdogg Posted February 10, 2021 Share Posted February 10, 2021 I just replaced mine with the stock Subaru studs. They make a tools to remove studs... all you need is enough stud sticking out to grab on to. https://www.google.com/search?q=stud+removal+tool&rlz=1C1GCEA_enUS749US749&oq=stud+removal+tool&aqs=chrome..69i57j0l7.3535j0j7&sourceid=chrome&ie=UTF-8 I have had luck with the socket type, especially when the tool is new. Link to comment Share on other sites More sharing options...
dgoodhue Posted February 10, 2021 Share Posted February 10, 2021 had anyone here had to replace the studs on the vf54 turbo? i need to do my timing belt and water pump and i know i have to remove the cat/j-pipe to do it. the nuts holding it on are about as bad as it gets and i have a feeling i will have to replace the studs while in in there. my questions are... 1. how the hell can i get the nuts off that pretty much have no sides to them? 2. any one replace there studs with a aftermarket kit like grimmspeed? or am i stuck getting them from Subaru? You can drop the exhaust manifolds and turbo/j pipe as one unit instead of removing the j-pipe from the turbo. Link to comment Share on other sites More sharing options...
11boostedgt Posted February 10, 2021 Author Share Posted February 10, 2021 stew. i have the stud extractors. not too worried about that. these nuts on them are going to fight me... dgoodhue.. i figured i could do that worst case. but i also want to upgrade the j pipe while im in there. Link to comment Share on other sites More sharing options...
motorbreath Posted February 10, 2021 Share Posted February 10, 2021 stew. i have the stud extractors. not too worried about that. these nuts on them are going to fight me... dgoodhue.. i figured i could do that worst case. but i also want to upgrade the j pipe while im in there. I tried this about a month ago with my 2010 LGT, got one stud out (the nut was completely rusted away), but could not get any of the others out. Once the weather warms-up I am going to drop the exhaust manifold/turbo/j-pipe as one assembly and work on it outside of the car. Link to comment Share on other sites More sharing options...
coco26 Posted February 11, 2021 Share Posted February 11, 2021 Mine was also extremely rusted. I hit them with PB Blaster almost every day for two weeks before I even tried, and I was able to get three of the nuts off with it in the car. The fourth one brought the stud with it. I was able to get the rest of the studs out once the turbo was out of the car with the double-nut method and replaced them with OEM studs (and nuts). If I had to do it again, I'd probably drop it as one piece just to be able to work on those nuts with better visibility. Link to comment Share on other sites More sharing options...
11boostedgt Posted February 11, 2021 Author Share Posted February 11, 2021 Dropping it all tougher may be my only option... I’m not against.... hell maybe why its all out I can up grade to a bnr 18g if I can find one for a reasonable price..... just didn’t know if anyone used aftermarket studs or stuck to oem... this car will be going under the knife when the weather breaks here in pa... I put it away for winter. And don’t need it as a daily. Thanks all. Link to comment Share on other sites More sharing options...
dgoodhue Posted February 11, 2021 Share Posted February 11, 2021 Even if your j-pipe bolts were not rusty they were hard to remove when new and likely would have require at least one new nut/stud. Link to comment Share on other sites More sharing options...
motorbreath Posted February 11, 2021 Share Posted February 11, 2021 Dropping it all tougher may be my only option... I’m not against.... hell maybe why its all out I can up grade to a bnr 18g if I can find one for a reasonable price..... just didn’t know if anyone used aftermarket studs or stuck to oem... this car will be going under the knife when the weather breaks here in pa... I put it away for winter. And don’t need it as a daily. Thanks all. I used OEM studs. Link to comment Share on other sites More sharing options...
