Loya1ty Posted February 12, 2019 Share Posted February 12, 2019 I'm going to give myself some experience painting on my OEM sets of wheels. Not worth it to pay the $ for powder coating, so I'll be doing the clean/sand/tack/primer/paint method. My question: I'd like to match them to the Crystal Black Silica color of the car, but would obviously pay more per can of automotive touch up paint for that color code. Would the duplicolor cans of gloss black blend well with the car's black paint? Pics would be helpful. I'm also debating on going with bronze, but I can research pics on how those would look. Thanks. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 12, 2019 Share Posted February 12, 2019 powder coat, paint prime will wear off quickly Link to comment Share on other sites More sharing options...
whitexc Posted February 12, 2019 Share Posted February 12, 2019 Interested in this as well as I am looking to refinish my stock wheels for summer duty. Sent from my moto z3 using Tapatalk Link to comment Share on other sites More sharing options...
Scooby Fan Posted February 13, 2019 Share Posted February 13, 2019 I had to redo one of my OZ rims last year (Costco screwed up the finish with bead seal when they did a repair for me).... I did it by scrubbing down the original silver paint with a green kitchen scrubby pad then wiped it with a damp cloth. After it dried I masked off the tire and valve stem and sprayed it with Trem-clad silver....3 very light coats Is it perfect? No....but unless you get down and check it close up you would never know. Having it professionally re-painted was going to be $300. BTW it is the front drivers side in the pic. Link to comment Share on other sites More sharing options...
FLlegacy Posted February 13, 2019 Share Posted February 13, 2019 powder coat, paint prime will wear off quicklyI painted my wheels years ago and the paint hasn't worn at all. I only cleaned them and then used degreaser by duplicolor to prep the wheels as well. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
Infosecdad Posted February 13, 2019 Share Posted February 13, 2019 I've painted a few sets of wheels, cleaned, light sand, prime, few coats of duplicolor. They've held up for years. Link to comment Share on other sites More sharing options...
Loya1ty Posted February 14, 2019 Author Share Posted February 14, 2019 For wheels that will get swapped for winters, I don't expect too terrible wear and tear on a spray can paint job. And as mentioned here and across da webz, some pretty decent results can be had if being patient and diligent. I think I'm going to go with the Bronze, so the black match issue can be avoided. Don't want to be accused of blackface wheels The wheels also might go on my Impreza for a few months before the Legacy's tires call it in. To have some fun though, I'm going to paint the inside of the wheel well black, and only the surface and lip of the wheel bronze. Finish it all off with clear coat. Now I just need to determine whether to spray the calipers red or purple (I like classic, but also different colors) Link to comment Share on other sites More sharing options...
amusa Posted February 19, 2019 Share Posted February 19, 2019 I painted a set of wheels and I even powder coat a set of rims. With painting wheels you have to clean and scuff it with sandpaper high grit then clean it again and prime it, paint it then clear coat it. You want to do it in section with a nice smooth strokes and even spray. Let everything cure for a few days or more then coat of wax. Link to comment Share on other sites More sharing options...
