ICE7 Posted November 17, 2020 Share Posted November 17, 2020 Hey guys...have anyone tried or wondered if the TOMIOKA RACING GTX2971 HYBRID BALL BEARING TURBO FOR SUBARU WRX 2015+ FA20 can work on the BM / BR legacy. Link to comment Share on other sites More sharing options...
creep_nu Posted November 17, 2020 Share Posted November 17, 2020 not without a lot of work. https://legacygt.com/forums/showthread.php/fa-headers-unicorn-280391.html basically, the vf54 has a different flange and core than the others, so unless you're swapping in a lot of stuff, you can't just bolt on a wrx turbo. there's a company in russia that makes a header that you can use different turbos with, or you can have a shop build out a custom header, but there's no other stock turbos that are plug and play. tomioka also makes a vf54 hybrid, and bnr supercars makes a couple hybrids that you can use as well...in fact FabSX has one for sale in the classifieds right now. Link to comment Share on other sites More sharing options...
ICE7 Posted November 17, 2020 Author Share Posted November 17, 2020 not without a lot of work. https://legacygt.com/forums/showthread.php/fa-headers-unicorn-280391.html basically, the vf54 has a different flange and core than the others, so unless you're swapping in a lot of stuff, you can't just bolt on a wrx turbo. there's a company in russia that makes a header that you can use different turbos with, or you can have a shop build out a custom header, but there's no other stock turbos that are plug and play. tomioka also makes a vf54 hybrid, and bnr supercars makes a couple hybrids that you can use as well...in fact FabSX has one for sale in the classifieds right now. Thanks for the insight...can you inform me of what WRX Turbo can bolt on to the BM9 legacy??? Link to comment Share on other sites More sharing options...
ICE7 Posted November 17, 2020 Author Share Posted November 17, 2020 not without a lot of work. https://legacygt.com/forums/showthread.php/fa-headers-unicorn-280391.html basically, the vf54 has a different flange and core than the others, so unless you're swapping in a lot of stuff, you can't just bolt on a wrx turbo. there's a company in russia that makes a header that you can use different turbos with, or you can have a shop build out a custom header, but there's no other stock turbos that are plug and play. tomioka also makes a vf54 hybrid, and bnr supercars makes a couple hybrids that you can use as well...in fact FabSX has one for sale in the classifieds right now. Thanks for the headsup...can you kindly inform me of what WRX Turbo fits on the BM9??? Link to comment Share on other sites More sharing options...
creep_nu Posted November 17, 2020 Share Posted November 17, 2020 no other turbos bolt on. Link to comment Share on other sites More sharing options...
Aphex28 Posted November 17, 2020 Share Posted November 17, 2020 As Creep said, none of the WRX turbos will bolt on. Both of the flanges are different than ours on it. (Header flange won't match up, and the downpipe flange is pretty different. Link to comment Share on other sites More sharing options...
ICE7 Posted November 26, 2020 Author Share Posted November 26, 2020 Guys, what do you all think about the new Garrett T25-550 Turbo. It's small and has a wide power range. I'm thinking of getting one for my BM9 legacy. I know, there will be a lot of fabrication to be done...but I believe it should work great in the car. What's your thoughts??? Link to comment Share on other sites More sharing options...
dsanford1029 Posted November 26, 2020 Share Posted November 26, 2020 What are your power goals? Sent from my SM-G960U using Tapatalk Link to comment Share on other sites More sharing options...
ICE7 Posted November 28, 2020 Author Share Posted November 28, 2020 What are your power goals? Sent from my SM-G960U using Tapatalk I'm looking for 300 to over 300HP once the vehicle can handle it. Link to comment Share on other sites More sharing options...
dsanford1029 Posted November 28, 2020 Share Posted November 28, 2020 I'm looking for 300 to over 300HP once the vehicle can handle it.The g25-550 is a great turbo and the numbers you are aiming for definitely work with that turbo in fact efficiency is dead on around 31lbs per minute. Just keep in mind that your low end power would suffer a bit. It is a expensive turbo and on other platforms it is making great power. Sent from my SM-G960U using Tapatalk Link to comment Share on other sites More sharing options...
dgoodhue Posted November 28, 2020 Share Posted November 28, 2020 I would just get one of the hybrid 18G. 300whp is no problem. You should be able to get 300whp out of the stock turbo. If I want more HP than that, I would look at IQ headers which opens up more turbo options. Link to comment Share on other sites More sharing options...
