Legacy0wn3r2018 Posted September 17, 2018 Share Posted September 17, 2018 Hi folks, the AC in this car doesn't get very cold, the interior won't go below 80 degrees with outdoor temps of 90 degrees F. So far, I've tried recharging it (it was overcharged), replacing the cabin air filter (no effect, but it was nasty), and checking the basics (fans coming on, clutch pulling in, ect.). It seems that if you set the climate control to it's coldest setting, the compressor still cycles, even if the interior is nowhere near the temp setpoint. What gives? I assume since there is an electronic box running the show, there must be some temperature sender somewhere in the dash, do those go bad? When the compressor is running though, the air is pretty cold, and both the high and low side pressures are normal. Any suggestions? Link to comment Share on other sites More sharing options...
r.lee89 Posted September 18, 2018 Share Posted September 18, 2018 Could be a bad evaporator temp sensor. It thinks it's freezing the evaporator then shuts the compressor off. Could even be a bad pressure sensor too. On a hot humid day the pressures should be around 190/35 Link to comment Share on other sites More sharing options...
Legacy0wn3r2018 Posted September 20, 2018 Author Share Posted September 20, 2018 Could be a bad evaporator temp sensor. It thinks it's freezing the evaporator then shuts the compressor off. Could even be a bad pressure sensor too. On a hot humid day the pressures should be around 190/35 Any way to test the evaporator temp sensor without tearing the dash apart? Link to comment Share on other sites More sharing options...
r.lee89 Posted September 22, 2018 Share Posted September 22, 2018 Yes the wires will always come out of the box. Is your system a auto or a manual air? Link to comment Share on other sites More sharing options...
08SpecB_DE Posted September 22, 2018 Share Posted September 22, 2018 Have you tried swapping the ac relay? Link to comment Share on other sites More sharing options...
Legacy0wn3r2018 Posted September 22, 2018 Author Share Posted September 22, 2018 Yes the wires will always come out of the box. Is your system a auto or a manual air? Automatic climate control, is this sensor something I can simply ohm out, like a thermocouple/thermistor, ore something more sinister? Have you tried swapping the ac relay? Not yet, I don't have any of those miniature relays on hand, can I safely swap it for one near it? I've also read something about shimming the compressor clutch, but if it needed shimming, wouldn't you hear it slipping? Link to comment Share on other sites More sharing options...
08SpecB_DE Posted September 22, 2018 Share Posted September 22, 2018 If its the same relay, you can swap them. Ive never heard of shimming the clutch so i cant speak about that. Link to comment Share on other sites More sharing options...
