VespaGTS Posted January 16, 2021 Share Posted January 16, 2021 Hi guys, I did the JDM headlight replacement and initially the corner lights worked. I would expect them to work because they are not part of the JDM wiring harness, they are stock. The rear corner lights do work when headlights or using the switch on the top steering column is turned on. It’s only the fronts? I replaced the incandescent bulbs with LED bulbs but that didn’t change anything even when I reversed the bulbs to test if installed with correct polarity. I suspected a fuse but there is still voltage going to the corner lights (see image)? Voltage seems low to me, but it’s a small bulb so I am kinda lost. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
VespaGTS Posted January 18, 2021 Author Share Posted January 18, 2021 Can anyone confirm this is the correct voltage for this plug? Link to comment Share on other sites More sharing options...
rhino6303 Posted January 18, 2021 Share Posted January 18, 2021 Can anyone confirm this is the correct voltage for this plug?I can try to check this evening. Link to comment Share on other sites More sharing options...
rhino6303 Posted January 19, 2021 Share Posted January 19, 2021 Can anyone confirm this is the correct voltage for this plug?I can try to check this evening.I get 12V. Link to comment Share on other sites More sharing options...
VespaGTS Posted January 19, 2021 Author Share Posted January 19, 2021 I get 12V. That sounds correct to me. So what the heck is happening? There is power but not enough, any ideas on what to do next? Link to comment Share on other sites More sharing options...
rhino6303 Posted January 19, 2021 Share Posted January 19, 2021 That sounds correct to me. So what the heck is happening? There is power but not enough, any ideas on what to do next?How did you power that clearance light? Check that connection. It's been a long time since I built my harness but I seem to recall that I had to splice either the power or ground for that light somewhere. Do your flashers and turn signals work correctly? Link to comment Share on other sites More sharing options...
