DoctorDaveLGT Posted May 2, 2019 Share Posted May 2, 2019 I upgraded the front sway bar bushings with 25mm ones from Rallitek. The new bushings are significantly wider then the previous ones and stick out a decent amount past the mounting bracket. Are there any vendors that make a wider bracket? Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted May 2, 2019 Share Posted May 2, 2019 yeah there are a bunch out there, I know summit has them. I ordered a set a while back but still awaiting on them to be shipped 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
Lux Posted May 3, 2019 Share Posted May 3, 2019 Doc, let me know what you find? @ampmcv Link to comment Share on other sites More sharing options...
mechanic58 Posted May 7, 2019 Share Posted May 7, 2019 I've got a random racket coming from the front suspension on my car, usually most noticable at lower speeds and maneuvering on rough terrain - some people have suggested its the sway bar bushings. You all got any input on this? Link to comment Share on other sites More sharing options...
grovlet Posted May 10, 2019 Share Posted May 10, 2019 I've got a random racket coming from the front suspension on my car, usually most noticable at lower speeds and maneuvering on rough terrain - some people have suggested its the sway bar bushings. You all got any input on this? Check the top mounting nuts for the front Struts - they tend to loosen and the strut rattles.... Link to comment Share on other sites More sharing options...
AWDFTW Posted May 10, 2019 Share Posted May 10, 2019 Contact traildogck here, I think he makes some. Link to comment Share on other sites More sharing options...
whitetiger Posted May 10, 2019 Share Posted May 10, 2019 Energy suspension universal swaybar bushings and brackets. Link to comment Share on other sites More sharing options...
mechanic58 Posted May 10, 2019 Share Posted May 10, 2019 Check the top mounting nuts for the front Struts - they tend to loosen and the strut rattles.... Welp, you nailed it. Link to comment Share on other sites More sharing options...
mechanic58 Posted May 10, 2019 Share Posted May 10, 2019 Well, sorta...was loose sway var links. Link to comment Share on other sites More sharing options...
grovlet Posted May 16, 2019 Share Posted May 16, 2019 Well, sorta...was loose sway var links. Glad to hear you found it - Link to comment Share on other sites More sharing options...
