dkelly701 Posted March 11, 2020 Share Posted March 11, 2020 I took the front bumper cover off of my 2010 to install headlight bulbs and found a wire connector not connected to anything and I didn't see anything to connect it to. It is located on the driver's side It has 2 wires and is taped to the wires for the plug that goes to the windshield washer fluid reservoir. I tried to upload a picture and I get an error every time I try. Thanks for any help. Link to comment Share on other sites More sharing options...
coco26 Posted March 11, 2020 Share Posted March 11, 2020 I believe that's for a secondary washer fluid pump, for the rear wiper on outbacks. Someone can correct me on that though. Link to comment Share on other sites More sharing options...
BonfaciosCuredMeats Posted March 11, 2020 Share Posted March 11, 2020 Coco nailed it. I had the same experience with my older Leggy - really weirded me out when I first found it. Sent from my Pixel using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted March 11, 2020 Share Posted March 11, 2020 Could also be for an intercooler sprayer, lol. Link to comment Share on other sites More sharing options...
dkelly701 Posted March 12, 2020 Author Share Posted March 12, 2020 Thanks for the replies. Glad it's nothing to worry about. Link to comment Share on other sites More sharing options...
creep_nu Posted March 12, 2020 Share Posted March 12, 2020 Could also be for an intercooler sprayer, lol. oh no...i don't need this but i totally need this Link to comment Share on other sites More sharing options...
FLlegacy Posted March 12, 2020 Share Posted March 12, 2020 oh no...i don't need this but i totally need this You need it, don't lie to yourself or to us! DO IT! Link to comment Share on other sites More sharing options...
creep_nu Posted March 12, 2020 Share Posted March 12, 2020 You need it, don't lie to yourself or to us! DO IT! wiper stalk and wiper fluid reservoir from a wrecked outback isn't more than a few bucks at the junk yard, couple sprayers and a couple feet of tubing...i mean...it's...intriguing. Link to comment Share on other sites More sharing options...
coco26 Posted March 12, 2020 Share Posted March 12, 2020 wiper stalk and wiper fluid reservoir from a wrecked outback isn't more than a few bucks at the junk yard, couple sprayers and a couple feet of tubing...i mean...it's...intriguing. I may or may not have already acquired and assembled all the parts necessary, and ran out of motivation to install them... my setup is a little more crude than this though. Link to comment Share on other sites More sharing options...
creep_nu Posted March 12, 2020 Share Posted March 12, 2020 I may or may not have already acquired and assembled all the parts necessary, and ran out of motivation to install them... my setup is a little more crude than this though. go on... Link to comment Share on other sites More sharing options...
coco26 Posted March 12, 2020 Share Posted March 12, 2020 Insert solenoid into the washer fluid line at the corner of the hood, one output continues to the washer nozzles, the other routes up the hood to the scoop area. There I made a bracket to mount a fuel injector rail (3 injectors, from a v6) to spray across the intercooler. Solenoid can be switched remotely to switch between windshield and intercooler sprayers. Getting a set of windshield nozzles and additional pump would probably be easier to package and acquire at a junkyard than that, but its what I had laying around. Link to comment Share on other sites More sharing options...
creep_nu Posted March 12, 2020 Share Posted March 12, 2020 oooh i like that fuel rail/injector idea...wonder if a washer pump produces enough pressure to get a good spray out of them. might be more fun to use those than windshield sprayers Link to comment Share on other sites More sharing options...
FLlegacy Posted March 12, 2020 Share Posted March 12, 2020 oooh i like that fuel rail/injector idea...wonder if a washer pump produces enough pressure to get a good spray out of them. might be more fun to use those than windshield sprayersI would use some misting or spraying nozzles from a irrigation system. Or new windshield washer nozzles, even new they are fairly cheap. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
creep_nu Posted March 12, 2020 Share Posted March 12, 2020 I would use some misting or spraying nozzles from a irrigation system. Or new windshield washer nozzles, even new they are fairly cheap. Sent from my SM-G965U using Tapatalk yeah i mean that definitely makes the most sense and would be easiest to do, but from a strictly #aesthetic standpoint the injectors on a rail would look about a billion times cooler. Link to comment Share on other sites More sharing options...
