bretwith1t Posted January 28, 2018 Share Posted January 28, 2018 2006 Legacy GT. Fuse #16 (Illumination) and #20 (Cigarette Lighter) I've been troubleshooting this issue, and i'm not sure where to turn next. I don't recall the cigarette lighter working since I purchased the car (4 years ago), and recently the red Illumination/radio backlights do not work. It's kind of a pain to change/see the radio buttons at night. For the Cigarette lighter #20 - The fuse will blow when the cigarette lighter does not have an accessory plugged in, and even when the assembly harness is unplugged. Illumination #16 - The fuse will blow the second I turn the headlight switch, even with the clock and radio assembly harness unplugged. Any thoughts on where to go next? My guess is maybe a ground wire, but I'm a novice when it comes to wiring. Any help is much appreciated! Link to comment Share on other sites More sharing options...
sshole Posted January 29, 2018 Share Posted January 29, 2018 Follow the wires for those circuits to see if there's a short in either circuit. Sounds like maybe the previous owner installed an aftermarket gauge and didn't uninstall it correctly. Link to comment Share on other sites More sharing options...
ehsnils Posted January 29, 2018 Share Posted January 29, 2018 Just look under the dashboard for loose wires hanging around. Wires can also have been jammed when the dashboard or piece of it has been remounted after a mod. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 29, 2018 Share Posted January 29, 2018 http://people.csail.mit.edu/ilh/vacation/ the service manual may help you follow the path of the wires. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 30, 2018 Share Posted January 30, 2018 Did you have the PS airbag replaced recently? Stealership certainly could have pinched something putting the dash back in. Link to comment Share on other sites More sharing options...
bretwith1t Posted January 31, 2018 Author Share Posted January 31, 2018 Thanks for all the insight! The previous owner did install a boost gauge in the cubby (circuit works fine, and illumation was not tapped into) so I ruled that out. I did pull out the cubby/clock and radio, and all the wires seem tidy in the factory harnesses and no half ass wiring jobs seem to be in play. The passenger side did have the airbag replaced for the Takata recall, is that something worth looking into? Link to comment Share on other sites More sharing options...
