whitetiger Posted June 10, 2015 Share Posted June 10, 2015 they'll be fine. no fixed perch spring on the market for the LGT will be too stiff or too low for konis. Link to comment Share on other sites More sharing options...
oaklandmiLGT Posted June 10, 2015 Share Posted June 10, 2015 Still loving my progress springs! Neutral handling, not too low (survives michigan roads) and not a bad pair with kyb gr2 (still get konis tho) Link to comment Share on other sites More sharing options...
Subyspec-b Posted June 12, 2015 Share Posted June 12, 2015 (edited) So I just purchased a set of bilstein HD struts/shocks and a set of H&R springs for my spec b. Does anyone have this setup? And do you like it? Also pics if you have. I really wanted to go with Epic, but could not find them anywhere. So I emailed Epic and they wrote back, saying " they were in the middle of gauging interest right now and I'll let you know if anything changes". So that's good news if they start making them again! But I couldn't wait any longer and pulled the trigger with the H&R springs. I hope I made a good choice. Edited June 12, 2015 by Subyspec-b Link to comment Share on other sites More sharing options...
R32 Posted June 17, 2015 Share Posted June 17, 2015 (edited) Wow I just went through all 81 pages. I've even inquired with some vendors. 07 Legacy Wagon GT Goal: Near OEM ride height (+/- 0.5" of ride height forgiveness) while retaining a stiffer overall suspension setup. From what I've read: 1. Go with H&R Sport springs with KyBs 2. Go with H&R Sport springs with Konis If choosing 1 or 2, use a 3/8 or taller lift spacer for the rear. Using 1 or 2 leaves the option for using aftermarket anti-roll bars as well. 3. If baller status, go with Feal Coilovers with full suspension height available. 4. Go with Rallitek springs w/KYBs If going 3 or 4, lift spacer not required, but aftermarket anti-roll bars are NOT recommended with the Rallitek springs. All setups should allow for 18 x 8 wheels without fender rolling. It took me A LOT of sorting just to find proper ride height photos. Edited June 17, 2015 by R32 Link to comment Share on other sites More sharing options...
oaklandmiLGT Posted June 18, 2015 Share Posted June 18, 2015 Wow I just went through all 81 pages. I've even inquired with some vendors. 07 Legacy Wagon GT Goal: Near OEM ride height (+/- 0.5" of ride height forgiveness) while retaining a stiffer overall suspension setup. From what I've read: 1. Go with H&R Sport springs with KyBs 2. Go with H&R Sport springs with Konis If choosing 1 or 2, use a 3/8 or taller lift spacer for the rear. Using 1 or 2 leaves the option for using aftermarket anti-roll bars as well. 3. If baller status, go with Feal Coilovers with full suspension height available. 4. Go with Rallitek springs w/KYBs If going 3 or 4, lift spacer not required, but aftermarket anti-roll bars are NOT recommended with the Rallitek springs. All setups should allow for 18 x 8 wheels without fender rolling. It took me A LOT of sorting just to find proper ride height photos. Why feal coilovers? Theres a thread on here basically saying theyre the same crap as bc, isc, ect.. if youre going coils it seems the good choice would be something like kw v2. But still coils are overkill if you just want a stiffer ride for street use. IMO out of all these options hr springs with konis is your best bet. I would say get epic engineering springs or eibach pro kit springs but good luck finding those. I went with progress lowering springs and kyb gr2 struts a month or so ago. The springs are great, you feel everything and the handling is much more neutral than stock. I live in michigan so the roads are crap, and although you feel most of the imperfections in the road, the ride isnt jarring. Ive never had a passenger complain. Really my only complaint, which isnt even a complaint about them, is that the bottom coils of the springs will make contact with each other and you can hear it sometimes. You can just coat the bottom coils in rubber to avoid this or get something like the rubber sleeves tien makes. I just let it be and everything is fine. i only notice it with the radio off and windows down while driving at low speeds. I am not as happy with the kyb gr2 struts. I wish i had gone with koni because these struts just dont feel like a good pair with lowering springs. Im no suspension expert but these struts feel under dampened like they cant keep up with the springs. usually it isnt an issue but if youre attacking a corner and hit a pavement change or bumpy section it doesnt stay as planted as it should. Link to comment Share on other sites More sharing options...
whitetiger Posted June 18, 2015 Share Posted June 18, 2015 2. Go with H&R Sport springs with Konis this is the correct option. Feal Coilovers? Don't make me laugh. Link to comment Share on other sites More sharing options...
R32 Posted June 19, 2015 Share Posted June 19, 2015 Feal coilovers were recommended by a local shop. Another recommendation was scale coilovers with lift spacers at all four corners. But I have no clue on the general performance of scale coilovers. My gut is to stick with a strut spring combo and use lift spacers at all four corners. 1" rear, 1/4" front. Link to comment Share on other sites More sharing options...
whitetiger Posted June 19, 2015 Share Posted June 19, 2015 I would also stay away from that local shop. They have no idea what they are saying. Def stick with a strut/spring combo. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 24, 2015 Share Posted June 24, 2015 I wish I could test my tire/kyb GR2/ Tien S tech combo however I never got to test it on a little rougher road yet.. in about 5 weeks or so the car will be drivable again. But the very short time I had it it felt somewhat stock like.. it's hard to say since the PO had cut the springs so it was a HUGE improvement.. and I know at least one of the coils in the rear broke. Link to comment Share on other sites More sharing options...
whitetiger Posted June 28, 2015 Share Posted June 28, 2015 S-techs on GR2. :vomit: what a horrible combo. Link to comment Share on other sites More sharing options...
Heffernan Posted July 22, 2015 Share Posted July 22, 2015 Anyone know what size spacers, if necessary, would be needed to keep the car level with an Eibach/Koni combo? I have an '08 Outback 2.5. Link to comment Share on other sites More sharing options...
R32 Posted July 23, 2015 Share Posted July 23, 2015 Anyone know what size spacers, if necessary, would be needed to keep the car level with an Eibach/Koni combo? I have an '08 Outback 2.5. It's a 1.4" drop front, 1.3" rear. Link to comment Share on other sites More sharing options...
Heffernan Posted July 23, 2015 Share Posted July 23, 2015 It's a 1.4" drop front, 1.3" rear. I think it's more like .9" f/r so I'm thinking 1/4" rear spacers would be fine. Link to comment Share on other sites More sharing options...
mikeydrives1 Posted August 22, 2015 Share Posted August 22, 2015 Just some insight from my setup... New suspension setup: JDM Spec B bilsteins all around -Fronts on LGT specific swift sedan springs (corrects front ride height) -Rears on OEM JDM springs (stiff like the swifts) and 3/8ths Subtle spacers/extended lugs to correct rear ride height. Overall it rides firmer but not harshly, like some setups do that ive been through on my other subarus. Theres about a 2-finger gap on each wheel still, measuring 25.5" from top of fender to ground in front and 26" from fender to ground in the rear. It was about 27-27.5 before all of this all around. Please note, this is on a 2.5i model, not a GT. I dont think these modifications are required on other LGT or Spec B (US) models to make JDM spec B suspension work due to the fact that those models are heavier with bigger motors/transmissions, compressing the suspension, esp in front, a little more. The issue with my 2.5i with the Spec B stuff was that it rode really high in the front because of the lack of a larger motor/6spd pushing down on it. Link to comment Share on other sites More sharing options...
jav2.5 Posted September 21, 2015 Share Posted September 21, 2015 Anyone know what a used set of Cobb springs are going for? 05-09 sedan I don't see any recent threads to go by. Link to comment Share on other sites More sharing options...
mikeydrives1 Posted September 22, 2015 Share Posted September 22, 2015 Cobb stopped making those awhile ago, so any set you find (IF any..) will be used. Link to comment Share on other sites More sharing options...
jav2.5 Posted September 22, 2015 Share Posted September 22, 2015 Cobb stopped making those awhile ago, so any set you find (IF any..) will be used. I have a set, just wanted to know what to ask. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted September 22, 2015 Share Posted September 22, 2015 Just mail them to me they aren't worth selling 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
xcruachan Posted October 13, 2015 Share Posted October 13, 2015 OK. Brand new forum guy also brand new to Asheville, NC. Anyone know of any action: clubs, good performance shops, autocross in this region? Next, suspension questions. And yes, I've already read most of the suspension comments. The recommendations for springs, bars, struts & braces are right on. But I didn't find anything about my specific question. Past experience: When I did my 69 BMW 2002, I was well taught & supervised, and did the whole nine yards. Plus a major league motor (150hp vs 110 stock). Then everything else started breaking! Turns out old 2002s aren't overbuilt like old American cars, so I had to put in a strut brace because my windshield kept popping out, all new bushings, box out the crossmember & control arms, hardened halfshaft bolts, etc. So the question is, how well do the other parts in a 2005 LGT hold up when you start messing around with performance suspension pieces? I'm hesitant to do the springs because of this question. How do the bushings, steering gear, top hats, (front sway bar mount?) etc. hold up? And what does anyone think about just doing good struts, a front strut brace & good adjustable bars on both ends? If that works, my main problem is that all of the high performance end links I found say, even if they are adjustable, that they are sized for lowered cars. Anyone know of any good end links of stock length? OK, congratulations if you made it through this monologue! And any feedback would be gratefully appreciated, as I am dying to pull the trigger & get the beast to go around corners like a real car. If there are already any posts about these issues, could someone maybe point me to them. Thank you all repeatedly, and happy handling to you. Link to comment Share on other sites More sharing options...
olivierdb Posted November 10, 2015 Share Posted November 10, 2015 This summer i bought the koni sports kit with h&r spring and im not too happy with it too low and stiff what would be my options to raise the car just a little and bring back some comfort!! Link to comment Share on other sites More sharing options...
whitetiger Posted November 10, 2015 Share Posted November 10, 2015 put the stock springs on the konis Link to comment Share on other sites More sharing options...
Qlee24 Posted December 10, 2015 Share Posted December 10, 2015 Hi everybody I did a legacy 06 2.5 I I am really interested in the eibach pro spring kit and I have stock struts I was wondering if the eibach pro springs will work on my stock 2.5 I struts. Anybody do this? Link to comment Share on other sites More sharing options...
Dylan.Pink Posted December 12, 2015 Share Posted December 12, 2015 What are some good lowering springs for a Gen3 Liberty? Link to comment Share on other sites More sharing options...
chrisrex Posted December 12, 2015 Share Posted December 12, 2015 hello friends Im going to swap out my stock struts for koni sports but I want to go with the Sti pink springs route part#st2033021000 for the front and #2038021010 for the rear. just wondering if anyone has run this combo on their car and if you could help in locating springs. I want to lower the car max 1 inch preferred .5 inch and for the car to have a slightly more aggressive ride from stock. any help would be greatly appreciated even if its a point in the right direction. Link to comment Share on other sites More sharing options...
Rhitter Posted December 15, 2015 Share Posted December 15, 2015 The reviews I have read of the STI pinks is that it's more than slightly aggressive. Aka it can be harsh. Can you fit STI pinks on Konis? Do you just need the JDM / Spec.B tophat for them to work? My OBXT build Link to comment Share on other sites More sharing options...
