ashwinearl Posted August 28, 2019 Share Posted August 28, 2019 Hi all, 2005 Legacy GT Wagon 5MT 155k I'm seeing smoke in the rear view mirror under hard acceleration sometimes. Typically in third gear with a hard acceleration, stomp. I can't tell a specific color. What are the recommended diagnostics to perform? Compression Test Leak Down Test block tester to test for head gasket leak Inspect turbo seal I know I have a small oil leak from what I think is the Oil cooler gasket Here is my mod list: Cobb AP V2 with Tuning Alliance Custom E tune Cobb Catless Up Pipe Cobb Catted Downpipe Cobb EBCS JMP Custom VF 40* (probably 40k miles on it) Grimspeed TMIC DW65c Fuel Pump Reference FPR to BOV, capped cyl 4 I want to get a health check anyway before the next step in mods. I'm going to post another thread specific to brainstorming what next. Thanks. Link to comment Share on other sites More sharing options...
Tehnation Posted August 29, 2019 Share Posted August 29, 2019 (edited) compression test 1st cause its easy, if you get wonky numbers or are inconsistent, well your probably screwed at that point, but do a leak down to be sure and dial in on the issue. You can drain the oil to check for headgasket leak, but the gt's aren't really known for blowing head gaskets its the 2.5i's. Lots of smoke to me usually points towards a blown ring or bad valves/seals., oil is getting by the rings/valve seals and burning up. inspect your turbo as well just to be safe. Edited August 29, 2019 by Tehnation Link to comment Share on other sites More sharing options...
