Darkryuux Posted June 18, 2014 Share Posted June 18, 2014 i have a 95 sub legacy brighton wagon with a cable driven clutch. i have purchased 3 different clutch assemblies with the most recent one being a complete set including new flywheel. i would love to have my legacy back on the road. if anyone can help please do. Sent from my SPH-L710 using Tapatalk Link to comment Share on other sites More sharing options...
Idaho subaru Posted June 19, 2014 Share Posted June 19, 2014 You may have to elaborate a little. Link to comment Share on other sites More sharing options...
Darkryuux Posted June 19, 2014 Author Share Posted June 19, 2014 My bad lol. My clutch pedal has no resistance when new clutch is installed. Pedal goes to floor and stays there. When I go to pull it back up the spring on the pedal snaps the pedal back up. Checked clutch cable already Sent from my SPH-L710 using Tapatalk Link to comment Share on other sites More sharing options...
Darkryuux Posted June 19, 2014 Author Share Posted June 19, 2014 As i stated before this is 3rd kit and still same problem, but if I put old assembly in I have a good pedal just the old kit is too far gone to use Sent from my SPH-L710 using Tapatalk Link to comment Share on other sites More sharing options...
Idaho subaru Posted June 19, 2014 Share Posted June 19, 2014 The adjustment is opposite of what you think it should be. Try loosening the adjustment nut. Link to comment Share on other sites More sharing options...
Darkryuux Posted June 19, 2014 Author Share Posted June 19, 2014 Tried loosening and tightening neither worked Sent from my SPH-L710 using Tapatalk Link to comment Share on other sites More sharing options...
Idaho subaru Posted June 19, 2014 Share Posted June 19, 2014 I had to look at mine again to see which way the adjustment went, have you tried tightening the adjuster all the way down? I just remember it seemed backwards to me, when the new clutch goes in you tighten the cable, and as the clutch wears, you loosen it. If that works, there is some fine tuning to keep the throw out bearing from riding the pressure plate continuously. If that doesn't work, maybe your clutch fork is either bent, or maybe not on the pivot ball correctly. Link to comment Share on other sites More sharing options...
Darkryuux Posted June 19, 2014 Author Share Posted June 19, 2014 Update on my clutch pedal issue. The way the pedal acts is the way it acts with no transmission attached Sent from my SPH-L710 using Tapatalk Link to comment Share on other sites More sharing options...
twisty Posted June 20, 2014 Share Posted June 20, 2014 sounds like the clutch plate may be on incorrectly. i had same issues the first time i taught my son to do a clutch, he didnt tighten the plates down correctly and had it bound up. once we pulled it, reset and torqued it down correctly, it worked well. you may want to check the TB down to the fork, then to the fingers, and see if they are contacting correctly Link to comment Share on other sites More sharing options...
Zues Marine Posted June 20, 2014 Share Posted June 20, 2014 Is there air in the lines? Link to comment Share on other sites More sharing options...
r3v_v3ng3 Posted June 20, 2014 Share Posted June 20, 2014 ^ its a cable trans Can you take a pic on how the cable is installed on the fork? Also take the cable line out and verify that the line is good (not snapped, weak, etc) Link to comment Share on other sites More sharing options...
Darkryuux Posted June 20, 2014 Author Share Posted June 20, 2014 Trans is not in atm but cable is good Sent from my SPH-L710 using Tapatalk Link to comment Share on other sites More sharing options...
Darkryuux Posted June 21, 2014 Author Share Posted June 21, 2014 http://img.tapatalk.com/d/14/06/21/asa3ugu7.jpghttp://img.tapatalk.com/d/14/06/21/ny5uqe2y.jpg This is how my clutch cable is hooked up Sent from my SPH-L710 using Tapatalk Link to comment Share on other sites More sharing options...
Idaho subaru Posted June 21, 2014 Share Posted June 21, 2014 Wow, that thing is way loose, you should have a lot more thread showing than that for a new clutch. I know, I said try loosening it first, but then corrected myself and said tighten. I'm easily confused! As I said earlier, I'd start with tightening the adjustment nut ALL the way down. Just for reference, I have a '97 Brighton, and I just did the clutch a few months back, I have about 1 1/4" of thread showing on the adjuster, I have hardly any threads left to tighten it anymore. If you already tightened it all the way down and that didn't do anything, then it's either what I or twisty said above, or something else crazy, like the wrong clutch altogether! I still holding out for an adjustment issue though.......the simplest remedy is most often the correct one. Just for kicks, try pushing on the fork by hand, if you can push it towards the fire wall more than 4-5 mm by hand, it's to loose. Link to comment Share on other sites More sharing options...
subikid90 Posted June 21, 2014 Share Posted June 21, 2014 broken clutch fork? -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Darkryuux Posted June 24, 2014 Author Share Posted June 24, 2014 I adjusted the cable again and checked pedal and evidently I had done something wrong before because the car is driving again....now to relearn clutch pedal due to engagement being about an inch off floor Sent from my SPH-L710 using Tapatalk Link to comment Share on other sites More sharing options...
Idaho subaru Posted June 24, 2014 Share Posted June 24, 2014 Awesome! I had a feeling. What you described is just what I was feeling when I did mine. A big DITTO on relearning the new clutch pedal feel, it is weird having it grab that close to the floor. Make sure your free play adjustment at the fork is good, if it's too tight, you'll wear out your throw out bearing prematurely. Link to comment Share on other sites More sharing options...
Darkryuux Posted June 24, 2014 Author Share Posted June 24, 2014 How much free play lol and how would I check it lol Sent from my SPH-L710 using Tapatalk Link to comment Share on other sites More sharing options...
