Nanci E. Posted June 12, 2014 Share Posted June 12, 2014 So, I've been trying to figure out if there is a way to check the transmission fluid on my 1992 Legacy, manual transmission. Or, maybe an even more important question, should I? When I put it in reverse today, I couldn't pull it out of reverse. It was suggested I check the transmission fluid, so I went online to figure out how to do this, and it seems there are two trains of thought: 1) it's not needed since it's a manual and 2) Yes, you should and you can find the dipstick on the driver's side of the car. So, do I need to check it, and if so, where do I do that?? Thanks! I know this might seem a silly question, but it truly is driving me crazy not being able to find a solid answer. Link to comment Share on other sites More sharing options...
subikid90 Posted June 13, 2014 Share Posted June 13, 2014 It will be on the passenger side of the trans right next to the firewall. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
94legacy22 Posted June 13, 2014 Share Posted June 13, 2014 4 qts gl4 90w. i used 3 quarts of it with 1quart lucas. Link to comment Share on other sites More sharing options...
