NavigatorsLegacy Posted July 6, 2019 Share Posted July 6, 2019 It just rained... passenger seat slightly damp. Water on floor is passenger mat. See photos. Help please?!?!?! How to fix or repair? Stealership review? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
DrD123 Posted July 6, 2019 Share Posted July 6, 2019 Good chance the drains for the sunroof are plugged - first see if there is debris up top, then maybe try blowing them out with compressed air https://legacygt.com/forums/showthread.php/water-leaking-top-during-raining-days-268534.html?t=268534 Link to comment Share on other sites More sharing options...
NavigatorsLegacy Posted July 6, 2019 Author Share Posted July 6, 2019 I will investigate and try to blow air out with a compressor... Hmm... not sure if Clogged but I do park under a tree shaded driveway... but where do I get an air compressor? Also, am I better off paying someone to do it (since I do not own one myself) or if I am unable to find anyone else who has access to one? I am a father of four on a budget. Thanks[emoji106] Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
dudemonster Posted July 6, 2019 Share Posted July 6, 2019 Had a clog in wife’s Mazda CX-9 from ac condenser under dash through drain to wall of transmission tunnel above heat shield. Was pissing out onto floor when full. Went under the car and used a can of compressed air meant to clean keyboards/electronics. Had a thin straw-like tube that came with and I stuck it in the drain outlet, sealed with fingertips and blew. It worked well. Something like that could be a cheap first step. Link to comment Share on other sites More sharing options...
NavigatorsLegacy Posted July 7, 2019 Author Share Posted July 7, 2019 How to access rear drains? Anyone know? Front two drains appear to be cleared from me pouring water through them and drip under car by tires... used rubber coated thin wire to act as snake down from two drain holes... don’t see rear drain holes... Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
DrD123 Posted July 9, 2019 Share Posted July 9, 2019 the rear drains are at the end of the rail for the sunroof panel - I don't know that you can get to them without lowering the headliner. You may be able to find the other end and snake the wire up the drain line... judging by the water stains in your car, though, if you have an issue with the drains, it looks to be the front ones. Link to comment Share on other sites More sharing options...
DugsSin Posted July 10, 2019 Share Posted July 10, 2019 If you decide to take it somewhere give this place a call since your in N.Jersey http://azpinstalls.com/web/ as see if they will help. Excellent place to have your maintenance/repair/modification work done. Link to comment Share on other sites More sharing options...
NVAKeith Posted July 13, 2019 Share Posted July 13, 2019 For anyone looking, the rear sunroof drain exits behind the rear bumper cover. Link to comment Share on other sites More sharing options...
